Posted March 16, 200916 yr comment_277711 Hey guys. I was wondering if people who have rear louvers can post some info about them, I know there are many different types and I'm interested in getting a set. I just don't know what to look for. Are there kinds that don't need to be bolted on or is that pretty much the only way to do it? Any help is appreciated. Thanks Link to comment https://www.classiczcars.com/forums/topic/31188-rear-hatch-louvers/ Share on other sites More sharing options...
March 16, 200916 yr comment_277716 I have a set where some metal brackets slides under the glass weatherstripping, the louver is made out of aluminum, they show up once in a while, just keep an eye open.Chris Link to comment https://www.classiczcars.com/forums/topic/31188-rear-hatch-louvers/#findComment-277716 Share on other sites More sharing options...
March 16, 200916 yr comment_277717 The Interpart Brand are attatched by sliding and glueing tabs between the hatch glass and the weatherstrip. They are locked by a cross shaped key that articulates a slide locking or unlockeing the louver.Most use a deadbolt type lock, and use sheet metal screws to mount to the hatch.Will Link to comment https://www.classiczcars.com/forums/topic/31188-rear-hatch-louvers/#findComment-277717 Share on other sites More sharing options...
March 16, 200916 yr comment_277721 I have also been thinking about buying a rear window louver. I know MSA sells them (be sure to tell them you are a member of this site and recieve a 10% discount of all your orders - you do need to know your CZCC account number). Does anybody have any pictures they can post. I have searched and did not come up with much info at all. I know there are two different types metal and plastic and my choice would be the metal. The price at MSA is $264.95 and a discount for club members at $238.46 - being a CZCC member does have its rewards, (are you a supporting member - another reason to be one, right?) freight to my area is $28.00 and it is a two piece put together unit. The MSA is attached with metal tabs not screwed into your hatch, and they told me it takes 10 minutes to remove it for cleaning if needed.That is all I know but would like to see some detailed pictures if anybody has made the purchase recently from MSA.Thanks in advance! Link to comment https://www.classiczcars.com/forums/topic/31188-rear-hatch-louvers/#findComment-277721 Share on other sites More sharing options...
March 16, 200916 yr comment_277724 Now we have two interested in louvers and i had mine up for sale in a longer period of time while the car still was in the US, hmmm.I bet shipping would be to high to ship it back.Chris Link to comment https://www.classiczcars.com/forums/topic/31188-rear-hatch-louvers/#findComment-277724 Share on other sites More sharing options...
March 16, 200916 yr comment_277725 Here in Oregon and Washington, they turn up on craigslist regularly. Often $40-60. But as noted above, shipping them might be expensive due to size and how easy they'd be to damage. Link to comment https://www.classiczcars.com/forums/topic/31188-rear-hatch-louvers/#findComment-277725 Share on other sites More sharing options...
March 16, 200916 yr comment_277736 I have had louvers on my car for about 32 years, back in 1977 the only ones I could get were the ones that bolted to the car. They are make of aluminum and were flat black. I painted them about 25 years ago to match the color of the car.If you want to see pictures look at me web site listed below. Look in Outside View and Closeup Details to see a lot of different images. If you plan on leaving them on for ever like I did then the bolt on will work. Link to comment https://www.classiczcars.com/forums/topic/31188-rear-hatch-louvers/#findComment-277736 Share on other sites More sharing options...
March 16, 200916 yr comment_277739 Don't know how these attach, but this outfit has a pair of NOS.http://www.centralhp.com/viewitem.php?productID=HAM-1001 Link to comment https://www.classiczcars.com/forums/topic/31188-rear-hatch-louvers/#findComment-277739 Share on other sites More sharing options...
March 17, 200916 yr Author comment_277753 Do the interpart louvers have a hinge so they lift up to clean the glass? Link to comment https://www.classiczcars.com/forums/topic/31188-rear-hatch-louvers/#findComment-277753 Share on other sites More sharing options...
March 17, 200916 yr comment_277772 I am going to be removing the set that I have on my 240 and selling them this week. This is the metal (aluminum) set that has two bolted hinges on the the top that allow the whole assembly to tilt up for cleaning the glass. The unit is secured by two allen screws at the bottom against rails that run under the weatherstripping of the rear glass. I will try to take some additional pics tomorrow of the setup. Link to comment https://www.classiczcars.com/forums/topic/31188-rear-hatch-louvers/#findComment-277772 Share on other sites More sharing options...
March 17, 200916 yr comment_277780 Are those HAMMOND louvers plastic or aluminum? and I noticed that web site also has Cragar brand in stock, that's really old school! Link to comment https://www.classiczcars.com/forums/topic/31188-rear-hatch-louvers/#findComment-277780 Share on other sites More sharing options...
March 17, 200916 yr comment_277783 I found this on craigslist for $25. http://corvallis.craigslist.org/pts/1060390629.html It looks like his dog took a leak on it though.Marc. Link to comment https://www.classiczcars.com/forums/topic/31188-rear-hatch-louvers/#findComment-277783 Share on other sites More sharing options...
