Posted March 18, 200916 yr comment_277870 just bought a 79 fairlady z. headlights dont work, i hear the relay kick with the running lights, but no relay kick for headlights, swapped smaller relays, nothing... i have power on both sides of the fusible link marked H.L.no fuse in the kick panel for it though Link to comment https://www.classiczcars.com/forums/topic/31202-no-headlights/ Share on other sites More sharing options...
March 18, 200916 yr comment_277872 You could have dirty contacts in the multi function switch. Sometimes this is not as easily found as one might think because when you use a tester you usually push hard enough to get a good contact but just normal pressure from the switch contacts isn't enough. I don't have a manual for a 79 so I can't tell you where the relay or wires might be. Link to comment https://www.classiczcars.com/forums/topic/31202-no-headlights/#findComment-277872 Share on other sites More sharing options...
