We Need Your Help! ×
4 Barrel Conversion
PRACERZ
Which SU's do you have? If you have the later flat tops get a set of the early round tops and you'll have a lot less problems.
FWIW, a 4 barrel intake and a good new carb are going to cost almost the same as a set of ZTherapy round tops.
If I were going to spend the money on a four barrel intake, the Holley Pro-Jection might be my pick. Only problem is the price.:sick:
