Posted March 27, 200916 yr comment_279006 ok so i bought a q45 vlsd r200 for my 73 240 z, what would i need to complete the swap. Link to comment https://www.classiczcars.com/forums/topic/31323-vlsd-r200-question/ Share on other sites More sharing options...
March 27, 200916 yr comment_279015 Are you sure it's not a 230 ?, well you will need a lot of work if it is, adapters is avalible, can't remember where.Chris Link to comment https://www.classiczcars.com/forums/topic/31323-vlsd-r200-question/#findComment-279015 Share on other sites More sharing options...
March 28, 200916 yr comment_279031 Try here. I think Ross just came out with mounting kits for these diffs. He can also supply custom flanges, hubs and stubs to use the 280zxt or Z32 CVs with these.http://www.modern-motorsports.com/Oh yeah, try the search feature next time........ Link to comment https://www.classiczcars.com/forums/topic/31323-vlsd-r200-question/#findComment-279031 Share on other sites More sharing options...
March 28, 200916 yr Author comment_279074 its a short nose r200 vlsd. So i would need the mount kit (of course) custom flanges, hubs and stubs. do u think this would workhttp://www.newoldstockmotorsports.com/product_info.php?manufacturers_id=4&products_id=57$215http://www.newoldstockmotorsports.com/product_info.php?manufacturers_id=4&products_id=59 Link to comment https://www.classiczcars.com/forums/topic/31323-vlsd-r200-question/#findComment-279074 Share on other sites More sharing options...
March 28, 200916 yr comment_279085 That only covers the rear mounting point and not the front. You'll need a front mount designed for the short nose diff as well. Did you check out the link I provided, or are you stuck on the bling of the billet? Link to comment https://www.classiczcars.com/forums/topic/31323-vlsd-r200-question/#findComment-279085 Share on other sites More sharing options...
March 29, 200916 yr Author comment_279172 hahah no doubt that billet is sexy. but i was thinkin the same as i was lookin through that site. I think i am gonna go with the kit it seems legit. I ll post pics when its finished. thanks for the help Link to comment https://www.classiczcars.com/forums/topic/31323-vlsd-r200-question/#findComment-279172 Share on other sites More sharing options...
March 30, 200916 yr comment_279183 It may help in the future to do some research before buying parts.... Link to comment https://www.classiczcars.com/forums/topic/31323-vlsd-r200-question/#findComment-279183 Share on other sites More sharing options...
March 31, 200916 yr Author comment_279318 its a has six bolt flange to where the cv shaft bolts up to the diff.http://www.modern-motorsports.com/catalog/mm_gallery.php?album=2008+March+Proto+Q45+R200+Mounting+Proven+Brian+G%2F&pic=DSCN1973.JPGis this a custom axle? what is it from? Link to comment https://www.classiczcars.com/forums/topic/31323-vlsd-r200-question/#findComment-279318 Share on other sites More sharing options...
March 31, 200916 yr comment_279323 its a has six bolt flange to where the cv shaft bolts up to the diff.http://www.modern-motorsports.com/catalog/mm_gallery.php?album=2008+March+Proto+Q45+R200+Mounting+Proven+Brian+G%2F&pic=DSCN1973.JPGis this a custom axle? what is it from?Research young patowan......Quote from MM:"You'll have to source your own R230 differential along with a total of 4 CV halfshafts, you end up mating the 4 inner flange style 6 bolt CV joints to our custom billet axles including our custom end stops. "http://www.modern-motorsports.com/catalog/product_info.php?cPath=32_53&products_id=65 Link to comment https://www.classiczcars.com/forums/topic/31323-vlsd-r200-question/#findComment-279323 Share on other sites More sharing options...
March 31, 200916 yr comment_279325 this looks to be a pretty expensive swap. probably cheaper just to get an r200 diff from a zx if you just want something more beefy. even getting a aftermarket lsd for a r200 dif seems cheaper than this r230 short nose swap.- to add just to add it up mount kit and custom hubs 495+495= 990 just to mount it. + what ever you paid for the vlsd r200 short nose. Edited March 31, 200916 yr by overdrivex Link to comment https://www.classiczcars.com/forums/topic/31323-vlsd-r200-question/#findComment-279325 Share on other sites More sharing options...
March 31, 200916 yr comment_279353 this looks to be a pretty expensive swap. probably cheaper just to get an r200 diff from a zx if you just want something more beefy. even getting a aftermarket lsd for a r200 dif seems cheaper than this r230 short nose swap.- to add just to add it up mount kit and custom hubs 495+495= 990 just to mount it. + what ever you paid for the vlsd r200 short nose.All absolutely true, and unless you are planning on making in excess of ~600hp or so, there really is no reason to go this route. That said, if this is what you want to do, this is what it will take. I plan on sticking with the L6 series engine so I went with the longnose 3.9 R200 and stock half-shafts for now, with a CV swap at some point in the future. The CVs are more of a want than a need for me. Link to comment https://www.classiczcars.com/forums/topic/31323-vlsd-r200-question/#findComment-279353 Share on other sites More sharing options...
