Try here. I think Ross just came out with mounting kits for these diffs. He can also supply custom flanges, hubs and stubs to use the 280zxt or Z32 CVs with these.
http://www.modern-motorsports.com/
Oh yeah, try the search feature next time........
That only covers the rear mounting point and not the front. You'll need a front mount designed for the short nose diff as well. Did you check out the link I provided, or are you stuck on the bling of the billet?
hahah no doubt that billet is sexy. but i was thinkin the same as i was lookin through that site. I think i am gonna go with the kit it seems legit. I ll post pics when its finished. thanks for the help
  nissun said:
its a has six bolt flange to where the cv shaft bolts up to the diff.
http://www.modern-motorsports.com/catalog/mm_gallery.php?album=2008+March+Proto+Q45+R200+Mounting+Proven+Brian+G%2F&pic=DSCN1973.JPG
is this a custom axle? what is it from?
Research young patowan......
Quote from MM:
"You'll have to source your own R230 differential along with a total of 4 CV halfshafts, you end up mating the 4 inner flange style 6 bolt CV joints to our custom billet axles including our custom end stops. "
http://www.modern-motorsports.com/catalog/product_info.php?cPath=32_53&products_id=65
this looks to be a pretty expensive swap. probably cheaper just to get an r200 diff from a zx if you just want something more beefy. even getting a aftermarket lsd for a r200 dif seems cheaper than this r230 short nose swap.
- to add just to add it up mount kit and custom hubs 495+495= 990 just to mount it. + what ever you paid for the vlsd r200 short nose.
Edited by overdrivex
All absolutely true, and unless you are planning on making in excess of ~600hp or so, there really is no reason to go this route. That said, if this is what you want to do, this is what it will take. I plan on sticking with the L6 series engine so I went with the longnose 3.9 R200 and stock half-shafts for now, with a CV swap at some point in the future. The CVs are more of a want than a need for me.
