April 4, 200916 yr comment_279756 Yeah, I've got the FSM, but it's nearly impossible to tell where it's actually located according to the diagrams.In the engine bay, passenger side, group of three, one nearest the front of the car.There is also another ignition relay under the dash,passenger side, high level, second one in towards the front. Edited April 4, 200916 yr by Nigel1943 forgot you guys drive on the wrong side of the road Link to comment https://www.classiczcars.com/forums/topic/31333-280zx-dies-while-driving-restarts-by-shaking-ignition-switch/?&page=2#findComment-279756 Share on other sites More sharing options...
April 5, 200916 yr Author comment_279884 if the inhibitor switch or relay were bad, why would the starter motor even turn? Link to comment https://www.classiczcars.com/forums/topic/31333-280zx-dies-while-driving-restarts-by-shaking-ignition-switch/?&page=2#findComment-279884 Share on other sites More sharing options...
April 6, 200916 yr comment_279911 if the inhibitor switch or relay were bad, why would the starter motor even turn?The inhibitor switch circuit appears to not only have an effect on the starter but also the ignition. Link to comment https://www.classiczcars.com/forums/topic/31333-280zx-dies-while-driving-restarts-by-shaking-ignition-switch/?&page=2#findComment-279911 Share on other sites More sharing options...
April 6, 200916 yr Author comment_279912 It appears to only have an effect on the starter motor, actually. The inhibitor relay is activated when the ignition switch is in the IG position, and I believe the inhibitor switch is the one that prevents the starter from turning when the shifter is not in park or neutral. The ignition relay is also triggered simultaneously... but it does not appear that the inhibitor relay or switch does anything to affect the actual coil. I just mulled over the wiring diagrams for an hour and I'm fairly confident in that. Link to comment https://www.classiczcars.com/forums/topic/31333-280zx-dies-while-driving-restarts-by-shaking-ignition-switch/?&page=2#findComment-279912 Share on other sites More sharing options...
April 12, 200915 yr Author comment_280543 It seems that it was the ignition module. I replaced it and haven't had a problem in several days. Link to comment https://www.classiczcars.com/forums/topic/31333-280zx-dies-while-driving-restarts-by-shaking-ignition-switch/?&page=2#findComment-280543 Share on other sites More sharing options...
