I connected a inline fuel gauge up to my 76 280z l28e and found my fuel pressure at idle is 100 psi.I also noticed my return line had swollen.So I took the hose off of the tank and the fuel rail then blew air from the return line to the tank and junk came out of the lines so I hooked it all back up and no change the return line is still swelling.It sounds great when you first start it and no smoke but after a few min. It start loading up with fuel and it sound like it has a big cam in it and starts smoking bad. Could there be a blockage in the tank?What should I try? What does the fuel pressure need to be?Could it be the fuel pressure regulator?
https://www.classiczcars.com/forums/topic/31363-fuel-pressure-issues/
If the gauge is hooked up properly, that is, between the fuel filter and the fuel rail, I would rule out any kind of blockage if you're getting 100 psi. I would suspect the fuel pressure regulator. The pressure should be 36.3 according to the FSM.
Recently Browsing 0
