Posted April 1, 200916 yr comment_279405 I know this really should be really simple... I have ordered the twin K&N air cleaners with air horns from msa and id like to clean up the intake manifold and such before they get here. When i go to remove the cover for the stock air filter, the two wingnut screws come loose, but then the cover just bumps into the left strut tower before it clears the air horn type things coming from the base plate of the air box, and those get in the way of me just lifting the cover and filter off. :stupid:Is there something i have missed or special technique to getting this thing off?Im sure the answer is right in front of me, but im just too blind to see it.Thanks in advance. Link to comment https://www.classiczcars.com/forums/topic/31369-air-cleaner-box-removal/ Share on other sites More sharing options...
April 1, 200916 yr comment_279459 One thing to check is that the air filter clears the air horns. Mine has a K&N filter and it just clears the air horns. Link to comment https://www.classiczcars.com/forums/topic/31369-air-cleaner-box-removal/#findComment-279459 Share on other sites More sharing options...
April 1, 200916 yr comment_279461 As I recall it requires a little effort. It's been a while and would likely come naturally to me if I were at the car but I think you have to separate the housing in such a way that you can first remove the air filter itself. Once the filter element is out the cover can clear the horns and strut tower. Link to comment https://www.classiczcars.com/forums/topic/31369-air-cleaner-box-removal/#findComment-279461 Share on other sites More sharing options...
April 1, 200916 yr comment_279468 Mine just slip off, but there is however not much room, what car do you have, a good advise is to put it in your signature.Chris Link to comment https://www.classiczcars.com/forums/topic/31369-air-cleaner-box-removal/#findComment-279468 Share on other sites More sharing options...
April 1, 200916 yr Author comment_279470 Mine just slip off, but there is however not much room, what car do you have, a good advise is to put it in your signature.ChrisThat's a good idea, ill do that now. Its a 1972 240z and as of yet, still completely stock.Thanks for the replies everyone, ill give it another wrestle this afternoon. Link to comment https://www.classiczcars.com/forums/topic/31369-air-cleaner-box-removal/#findComment-279470 Share on other sites More sharing options...
April 1, 200916 yr comment_279482 I seem to remember having to spin it so that the snorkel is more or less pointing up. It definitely takes some 'finnageling' Link to comment https://www.classiczcars.com/forums/topic/31369-air-cleaner-box-removal/#findComment-279482 Share on other sites More sharing options...
April 2, 200916 yr comment_279508 You have to pull the back edge away first and then spin it down so that the snorkel is pointed up a little. It is even more fun with a strut bar across the top of the engine.Oh, and when you put it back on be sure that the wing nut screws are in the cover before you put it in place because the front one will NOT go in afterward, it is too long. Link to comment https://www.classiczcars.com/forums/topic/31369-air-cleaner-box-removal/#findComment-279508 Share on other sites More sharing options...
April 2, 200916 yr Author comment_279569 well, after fiddling with it a couple more times i still couldnt get it off. I found that the PCV tube had a metal tube inside the case and it was getting stuck on the filter and was preventing me from spinning the cover at all. so after getting frustrated enough i took a hack saw the the little metal tube (im not going to be using anymore) and then i was able to get it off with a little more wrestling. Not the ideal way im sure, but it worked Link to comment https://www.classiczcars.com/forums/topic/31369-air-cleaner-box-removal/#findComment-279569 Share on other sites More sharing options...
April 3, 200916 yr comment_279637 [quote name=TriDawIs there something i have missed or special technique to getting this thing off?Im sure the answer is right in front of me, but im just too blind to see it.Thanks in advance. Just allow the rear of the air cleaner to lower and then with it pointing upward, just slide it toward the front of the engine and it will slip right out . Save the air cleaner in case you become tired of smelling fumes and want to reinstall it later. Gary Link to comment https://www.classiczcars.com/forums/topic/31369-air-cleaner-box-removal/#findComment-279637 Share on other sites More sharing options...
