PATZ Posted April 5, 2009 Share #1 Posted April 5, 2009 HI ALL! I was referred to a TOE-IN Calculator (converts TOE inches to TOE degrees) at HybridZ.org. I was required to plug in the ff: Tire width, Tire profile, Wheel diameter and of course the TOE inches i wanted converted to degrees. My question then is: Does this mean that the FACTORY (Stock) alignment values (Toe in this case) for a stock 240Z with the stock sized rim-tires (obviously) apply to a differently sized rim-tire combo (in my case, 15" rims w/ 205/55 tires)? This is not for racing applications, but for everyday driving. THANKYOU! patrick Link to comment Share on other sites More sharing options...
doradox Posted April 5, 2009 Share #2 Posted April 5, 2009 HI ALL! I was referred to a TOE-IN Calculator (converts TOE inches to TOE degrees) at HybridZ.org. I was required to plug in the ff: Tire width, Tire profile, Wheel diameter and of course the TOE inches i wanted converted to degrees. My question then is: Does this mean that the FACTORY (Stock) alignment values (Toe in this case) for a stock 240Z with the stock sized rim-tires (obviously) apply to a differently sized rim-tire combo (in my case, 15" rims w/ 205/55 tires)? This is not for racing applications, but for everyday driving. THANKYOU! patrickYou should plug in the stock numbers for tire/wheel size etc. This will give you the stock angle which is totally independent of wheel tire combo. Toe-in in inches will give different angles depending on wheel and tire size. Angle is the same for all wheel and tire combos. That's a reason that angle is used by your alignment folks, it takes tire size out of the equation.Steve Link to comment Share on other sites More sharing options...
PATZ Posted April 7, 2009 Author Share #3 Posted April 7, 2009 DORADOX- THANKS for the reply! I better catch up on my reading... Link to comment Share on other sites More sharing options...
