Posted April 6, 200916 yr comment_279891 I just recently got my z running, while the rear was up on stands I found that when i turned the right (passenger) wheel, the left (driver) wheel would spin the opposing direction, just like all the other cars I have owned. But when I try to spin the left wheel, the right wheel stays stationary. I started the car and put it in first and both of the wheels were moving. Also the other day when the ground was wet, i could only spin my right tire, not my left. I have heard that sometimes the spider gears will give out in the diffs, what do you think it is? Link to comment https://www.classiczcars.com/forums/topic/31417-i-think-my-differnetial-is-shot/ Share on other sites More sharing options...
April 6, 200916 yr comment_279892 I just recently got my z running, while the rear was up on stands I found that when i turned the right (passenger) wheel, the left (driver) wheel would spin the opposing direction, just like all the other cars I have owned. But when I try to spin the left wheel, the right wheel stays stationary. I started the car and put it in first and both of the wheels were moving. Also the other day when the ground was wet, i could only spin my right tire, not my left. I have heard that sometimes the spider gears will give out in the diffs, what do you think it is?Sounds normal. Maybe a little brake drag in the right wheel which would cause it to not spin when you were up on the stands. The driveshaft would have been spinning instead. When a spider gives out you go no where, and often there are lots of bad expensive sounding noises.Steve Link to comment https://www.classiczcars.com/forums/topic/31417-i-think-my-differnetial-is-shot/#findComment-279892 Share on other sites More sharing options...
April 6, 200916 yr comment_279894 Also the other day when the ground was wet, i could only spin my right tire, not my left. I have heard that sometimes the spider gears will give out in the diffs, what do you think it is?The first part is totally normal for an open diff as doradox mentioned. To fix the one wheel peel, you'll need a limited slip. Link to comment https://www.classiczcars.com/forums/topic/31417-i-think-my-differnetial-is-shot/#findComment-279894 Share on other sites More sharing options...
April 6, 200916 yr Author comment_279895 thanks, im sure relieved that this is normal. To fix the break drag do i just adjust the screw inside the brake druim? Link to comment https://www.classiczcars.com/forums/topic/31417-i-think-my-differnetial-is-shot/#findComment-279895 Share on other sites More sharing options...
