Going to get into the carbs a bit, but I'm kinda scared, knowing nothing about them. I have a big bucket of that parts/carb cleaner, and a can of the spray stuff.
I'm sure most of you know this, but these are the kind of carbs I have;
http://paltech1.com/db5/00485/paltech1.com/_uimages/240ZCarbs001.jpg
I want to use the parts dip but I don't want to melt any gaskets, rings, or hoses inside. How..."Apart" does a carb get? Or is the spray good enough?
Thanks.
Edit: Ok started to take off the mounting bolts, only to find what looks to be coolant pour out. Guess I'm not taking it off at that point...Don't know why coolant is that close to the carbs either. Or oil. Why is there oil in them?
Edited by Wargasm
https://www.classiczcars.com/forums/topic/31479-attempting-to-clean-carbs/
Just order the "Just SU's" video from bruce at ZTherapy. Here's the info from the page.
http://www.ztherapy.com/products/videos/just_SU.htm
And order it from here.
www.ztherapy.com It's the best money you'll spend for a do it yourselfer.
Let me throw out a hypothetical for you all...Say...Hypothetically your whole air filter assembly fills up with fuel. How might that happen? :P
That means your floats are messed up. They are either stuck open or you adjusted them wrong. They will continue to empty fuel into the carbs and air filter and PRAY TO GOD THAT YOU DON'T BACKFIRE WITH ALL THAT FUEL IN THE FILTER....
Order the DVD and educate yourself, I did and now people ask me for help when adjusting or rebuilding their SU's.
A ha! When you say adjustment you're referring to the little brass looking piece with the plunger that presses down on the metal hinge attached to the float? If so, I put new ones in that came with my carb kit, didn't know there was an adjustment to make. I guess I'll learn how to adjust them. :D Thanks.
Awesome. I put the old piece back on (it looked newer anyways, I just replaced it because I had a new one on hand), and it works fine again. No leaks. The two pieces did look a little different, the older one had a fatter plunger on it, and was slightly shorter, so I guess there's the answer. Next step, get a new air filter. :P
Edited by Wargasm
If you look closely at the ZTherapy website it says "call to order, we do not offer online ordering"
Call Bruce, you'll be glad you did.
Guess I'll try again. A Z tune up video would be invaluable.
Edit: Cool, he called and I got the dvd on the way. The area code came up 503, which is Oregon, where I'm from. He said once I get transferred back to Oregon guard base in July that I should contact them because they have a lot of events up there.
Edited by Wargasm
Recently Browsing 0
