Email logins are now active ×
Compression of an E88 head
guy_geo
Not by today's standards, no. Actually, I think the highest compression for any of the L-series engines here in North America was 9.0:1.
There were at least 4 major versions of heads which carried the E88 casting number.
  1. Late '71 were very similar to the E31 combustion chamber, but slightly lower compression, had a CR of 8.7:1 or so.
  2. '72 had a different combustion chamber shape, and a CR a bit lower yet, about 8.3:1. (Sometimes called "small-chamber" E88.)
  3. '73 changed the chamber shape yet again, CR about the same as the '72, maybe a touch lower. (Sometimes called "larger-chamber" E88.)
  4. '74 was much the same chamber as the '73, but had larger exhaust valves.
Hi Guys:
I'm not sure where Jeff/Arne got 8.3:1 CR for the 1972 Model Year L24. The Factory Service Manual says it's 8.8:1.
After gathering statistics from several engines, most of the engine builders agreed that it actually comes out to the following.
L24 E-31 Head
Swept volume = 398.9cc
Combustion Chamber = 42.4cc (E31 Stock)
Gasket volume = 7.61cc
Deck Height = - 0.174 cc
42.4+7.61-0.174 = 49.836
49.836+398.9 = 448.736
448.736 / 49.836 = 9.004:1 compression ratio
L24 E88 Head (72 Model Year)
Combustion Chamber = 44.7cc (E88-1972)
Gasket volume = 7.61 cc
Deck Height = -0.174
44.7+7,61-0.174 = 52.136
52.136+398.9= 451.036
451.036 / 52.136 = 8.65 : 1
Note: Deck Height is as measured, not published in the service manuals. Nonetheless Nissan seems to have included the deck height - as they reported 9:1 c/r for E31 Heads. But then Nissan reports 8.8 : 1 for 1972 Model Year, although it calculates out to 8.65 : 1
As you can see - if you play with the numbers - taking a few thousands off an E88 to assure it is flat, or un-shrouding the valves, or adding larger valves - - will all change the C/R to a great extent. As they can all increase/decrease the total combustion chamber volume.
With the pump gas available in most parts of the country - and lacking a modern engine management system - you really don't want to go much over a 9:1 CR for a street engine. If you do, you have to run 93 Octane, and have your timing spot-on at all times. It also leaves you no room for any possible future over-heading/blown headgasket episodes if that head needed to be milled again...
FWIW,
Carl B.
Looks like I have flat top pistons....
If you have a stock L24 - you should have flat top pistons. But you don't have L28 size flat tops. So you won't have 10+ : 1 compression ratio's on your L24. (unless you over-bore the block an install larger pistons, or lengthen the stroke etc.).
FWIW,
Carl B.
  • 4 weeks later...
OK.
I'm trying to fond out the + side or - side of the combo engine I have..
280ZX block
240Z head E88
OE cam
Headers
Anything special???
Why did the previous onwer told me I have a special engine???
Depends which 280ZX block it is. If it's a '81-'83, then you have the flat top pistons. Those with an E88 head should give you around 10:1 CR (depending on other work it could be a bit more or a bit less). If you have a '79 or '80 ZX block, then no, it's just a 2.8L with 8.3:1 CR.
  • Who's Online   1 Member, 0 Anonymous, 370 Guests (See full list)
