April 18, 200915 yr comment_281083 It still sounds like dieseling to me. If there was a wiring issue that kept voltage going to the coil the car would run a lot longer than 5 or 10 seconds. The float bowls on a typical car hold enough gas for the car to idle at least a minute or more.Cars that diesel typically are running rich, and the fuel octane is too low. If the engine has a lot of miles on it and has a carbon buildup in the chambers that contributes to the problem as well.I had several mid-80's Chevys with V8's and that stupid electronic carburetor GM made, that would run-on for several minutes if we put regular gas in the tank. One of them was so bad that it would keep running even with the transmission in drive.:mad:I guess you could test the theory by undoing your wiring, temporarily wiring the pump directly to the battery (with a switch), and seeing if that changes the symptoms. Link to comment https://www.classiczcars.com/forums/topic/31505-shut-car-off-feul-pump-off-car-keeps-going/?&page=2#findComment-281083 Share on other sites More sharing options...
April 19, 200915 yr Author comment_281100 So you have the pump on a seperate switch and the ignition off the ignition switch, right? yes, the oem ignition is still there just a turn dial now instead of key's, later i'm going push button but need to takle one bug at a time. The pump is on it's very own switch, from the battery, to the switch, to the pump. A hot wire i guess. i did use the factory black wire as my pump ground assuming that's what it was, to ground the pump. the switch has it's own ground. Link to comment https://www.classiczcars.com/forums/topic/31505-shut-car-off-feul-pump-off-car-keeps-going/?&page=2#findComment-281100 Share on other sites More sharing options...
April 19, 200915 yr Author comment_281101 It still sounds like dieseling to me. If there was a wiring issue that kept voltage going to the coil the car would run a lot longer than 5 or 10 seconds. The float bowls on a typical car hold enough gas for the car to idle at least a minute or more.Cars that diesel typically are running rich, and the fuel octane is too low. If the engine has a lot of miles on it and has a carbon buildup in the chambers that contributes to the problem as well.I had several mid-80's Chevys with V8's and that stupid electronic carburetor GM made, that would run-on for several minutes if we put regular gas in the tank. One of them was so bad that it would keep running even with the transmission in drive.:mad:I guess you could test the theory by undoing your wiring, temporarily wiring the pump directly to the battery (with a switch), and seeing if that changes the symptoms.That's how it's already wired. Link to comment https://www.classiczcars.com/forums/topic/31505-shut-car-off-feul-pump-off-car-keeps-going/?&page=2#findComment-281101 Share on other sites More sharing options...
