Buying my first z today!!
'77az280z
Put in a diff from an auto car. Higher ratio which will lower your revs.
Makes for a nicer drive IMHO. You would need to swap the speedo drive on the gearbox for a different one to correct your speedo reading, but that is very easy done.
I have a diff from an auto 3.54-1 ratio in my 72 and it does 3000 at 60 mph in fourth. I never use fifth.
Edited by olzed
The fuel smell could very well be the rear weather strip. Either it has been removed or it is rotted. As you drive along the car creates a vacuum behing it sucking the smell of the exhaust right into the car. A BIG WELCOME. I echo what everyone else says about modifications. Get it road worthy and ultra reliable first and then knock off one improvement at a time. May you drive many miles with a BIG :)
  • 4 weeks later...
http://www.desertzassociation.com/
http://desertdatsuns.freeforums.org/index.php
These are the two z clubs here in the valley. Desertz is the older of the two and the members are older, more of a social group with lots of events. The other is limited to cars older than 1984. A much younger group that is more tech oriented.
Check them out as they can provide a lot of information. DesertZ costs $30.00 a year but gets major discounts at the dealerships for parts and service.
