Posted April 14, 200916 yr comment_280784 I have been trying to get ahold of Tabco for a outer wheel well rh and they seem to be shutdown as the phone numbers all are disconnected. Does anyone have any info on thisthax Dan Link to comment https://www.classiczcars.com/forums/topic/31515-tabco-panels/ Share on other sites More sharing options...
April 14, 200916 yr comment_280786 I talked with them yesterday, I am also in the market for the same part as you, but for both sides. They do not have any in stock at this time...... he asked me to call back in a couple weeks and should have some ready for shipping. Wait and see. Link to comment https://www.classiczcars.com/forums/topic/31515-tabco-panels/#findComment-280786 Share on other sites More sharing options...
April 14, 200916 yr Author comment_280793 thanx for the info....would you happen to have a contact # other than the ones on their website as I have tried them and got a disconnected message.thanx again Link to comment https://www.classiczcars.com/forums/topic/31515-tabco-panels/#findComment-280793 Share on other sites More sharing options...
April 14, 200916 yr comment_280796 here ya go 1 800 782 5226 Link to comment https://www.classiczcars.com/forums/topic/31515-tabco-panels/#findComment-280796 Share on other sites More sharing options...
April 15, 200916 yr comment_280804 Robin.....There's a driver side wheel arch on ebay right now....item # 110374809288 with 23 hours remaining. Buy it now for $52.00. Guy Link to comment https://www.classiczcars.com/forums/topic/31515-tabco-panels/#findComment-280804 Share on other sites More sharing options...
April 15, 200916 yr comment_280840 thanks for the heads up Diseazd! wrong part though, i am needing the wheel arch housing (housing inside the quarter panel). Link to comment https://www.classiczcars.com/forums/topic/31515-tabco-panels/#findComment-280840 Share on other sites More sharing options...
April 15, 200915 yr Author comment_280873 thanks Robin I'll give them a try in 2 weeks Link to comment https://www.classiczcars.com/forums/topic/31515-tabco-panels/#findComment-280873 Share on other sites More sharing options...
April 15, 200915 yr Author comment_280884 ok......tried the number and got a cannot connect message, could it be I'm in canada, I also tried the 216 number from their website. I'll try email next. anyone else have this problem.thanks for any help Link to comment https://www.classiczcars.com/forums/topic/31515-tabco-panels/#findComment-280884 Share on other sites More sharing options...
April 16, 200915 yr comment_280909 I ended up buying 2 lefts by accident when I did the metal work on my 240, Part# 16753L. If you cant get ahold of them and need one now just PM me. I wont be needing it anytime in the foreseeable future. I also have an extra left side wheel arch that I didn't use if you need it, Part # 16751L Link to comment https://www.classiczcars.com/forums/topic/31515-tabco-panels/#findComment-280909 Share on other sites More sharing options...
April 16, 200915 yr comment_280946 pm sent...Dan S your looking for the right side only, correct? If you are needing the left side you should have first dibs on this. Edited April 16, 200915 yr by Robin Link to comment https://www.classiczcars.com/forums/topic/31515-tabco-panels/#findComment-280946 Share on other sites More sharing options...
April 16, 200915 yr Author comment_280971 that's correct, just the right hand outer wheel well......pls keep your eyes and ears openthanx.......also gonna try that other # and go to a zcar swap meet this sat. in Toronto Link to comment https://www.classiczcars.com/forums/topic/31515-tabco-panels/#findComment-280971 Share on other sites More sharing options...
April 16, 200915 yr comment_280977 Dan, give Charlie Osborne a call at Zedd Findings. I know he has had Tabco stuff in the past. He's in Kitchener and usually ships out right away if he has it in stock. He may take awhile to reply to emails so give him a call. Heres his website:http://www.datsunzparts.com/ Link to comment https://www.classiczcars.com/forums/topic/31515-tabco-panels/#findComment-280977 Share on other sites More sharing options...
