Posted April 15, 200916 yr comment_280878 I will be attempting the rear suspension rebuild shortly, got my Z out of storage and a rear strut has gone bad!Where can I purchase a spindle pin pullerThanks Mark Link to comment https://www.classiczcars.com/forums/topic/31526-spindle-pin-pullerwho-has-one/ Share on other sites More sharing options...
April 15, 200916 yr comment_280889 http://cgi.ebay.com/ebaymotors/240Z-280Z-Datsun-Rear-Spindle-Pin-Strut-Pin-Puller_W0QQcmdZViewItemQQ_trkparmsZ72Q3a1205Q7c66Q3a2Q7c65Q3a12Q7c39Q3a1Q7c240Q3a1318Q7c301Q3a1Q7c293Q3a1Q7c294Q3a50QQ_trksidZp3286Q2ec0Q2em14QQhashZitem120394103277QQitemZ120394103277QQptZMotorsQ5fAutomotiveQ5fTools#ht_500wt_1218Built by a club member here. I've used one, it does the job. Link to comment https://www.classiczcars.com/forums/topic/31526-spindle-pin-pullerwho-has-one/#findComment-280889 Share on other sites More sharing options...
April 15, 200916 yr comment_280891 Just to be sure, if all you're looking to do is replace the strut insert, there is no need for the spindle pin puller. If on the otherhand you're planning on replacing the outer link bushings, you will almost certainly need the puller. Link to comment https://www.classiczcars.com/forums/topic/31526-spindle-pin-pullerwho-has-one/#findComment-280891 Share on other sites More sharing options...
April 16, 200916 yr Author comment_280966 Thanks guys,I'm going to rebuild the suspension, everything appears to be 38 years old!Mark Link to comment https://www.classiczcars.com/forums/topic/31526-spindle-pin-pullerwho-has-one/#findComment-280966 Share on other sites More sharing options...
April 16, 200916 yr comment_280975 Mark, I have a puller that I will loan if you pay the shipping both ways, and return it in a timely manner when you are finished with it. The shipping costs are are about nine dollars each way via US Mail. The puller makes the job of pulling the pins easy , if the rust damage to the suspension isn't severe. The new puller I have is so strong that it will actually pull the pin apart if it is so embedded with rust that it is ''welded'' in place. If you or anyone else has been hitting the spindle pin , trying to knock it loose or out. Don't bother with the puller. Because It must be attached to the end of the pin and if the threaded end is damaged , it will not work. The old pins are reusable so don't buy new ones until you have a look at yours. They are about $25.00 ea. Send me a PM . Gary Edited April 16, 200916 yr by beandip more info Link to comment https://www.classiczcars.com/forums/topic/31526-spindle-pin-pullerwho-has-one/#findComment-280975 Share on other sites More sharing options...
