Email logins are now active ×
Wheel rubbing against fender
'77az280z
Not true. The TC rod length affects caster and its common to use one or two precision ground washers to get caster equal side to side.
Also, be aware that the right front wheel on a LHD S30 is slightly further forward then the left front wheel. That's designed in by Nissan.
Yep, I had to fine tune mine with washers on the LH TC rod to get the alignment correct. John, do you know how much the RH side leads by?
