Email logins are now active ×
Checking Cold Start Valve
chiefmd
I'm in the process of replacing numerous parts to remedy "running rich" in a 78 280Z. The last item is the csv but I want to be certain that it is or is not functioning. Is there any way to bench check it off the car, similar to the 9 volt test for the injector. I know you can check it while its installed on the car but I'm working on the motor and don't want to put everything back just to check the csv. Thanks
