Posted April 20, 200915 yr comment_281267 So, this is my first time driving my '78 Z on a regular basis in such hot weather. A recent heat wave has brought temperatures well into the 90s. Here's the problem: When I go to start it (cold engine), it runs fine. But when I park and return to start it within 20 or 30 minutes (engine still hot), it doesn't start. It takes a long time to finally get it running, and once I do it runs great. I'm aware that vapor lock is non-existent with EFI, so are there any other diagnoses? Does it have to do with the heat or is that just a coincidence? Link to comment https://www.classiczcars.com/forums/topic/31588-78-280z-has-trouble-starting-in-hot-weather/ Share on other sites More sharing options...
April 20, 200915 yr comment_281270 Mine started doing the similar thing at the end of last summer/fall season before I put it away for winter storage and I haven't had a chance yet to correct it. My guesses so far that I'm thinking off the top of my head is either A) Faulty Coolant Temp Sensor or possibly I got a bad check valve in the fuel pump and it's not maintaining 36.3 fuel pressure like it's suppose to which is causing the "Hard to restart" issue. If I shut mine down and restart it right away it fires up instantly. It only struggles to start after sitting for a period of time so I'm kinda leaning towards B. I'm not sure yet. I got to do some testing myself Edited April 21, 200915 yr by DatsunZsRule Link to comment https://www.classiczcars.com/forums/topic/31588-78-280z-has-trouble-starting-in-hot-weather/#findComment-281270 Share on other sites More sharing options...
April 21, 200915 yr comment_281283 I concur with solution B. If it was solution A, it wouldn't run right once warm but it would start. Link to comment https://www.classiczcars.com/forums/topic/31588-78-280z-has-trouble-starting-in-hot-weather/#findComment-281283 Share on other sites More sharing options...
April 21, 200915 yr comment_281286 yeah thats my thought as well. Looks like mtndude isn't too far from you stephen ( San Bernardino, CA) Link to comment https://www.classiczcars.com/forums/topic/31588-78-280z-has-trouble-starting-in-hot-weather/#findComment-281286 Share on other sites More sharing options...
April 21, 200915 yr comment_281289 We've corresponded. He's just up the hill 20 minutes or so from me. Link to comment https://www.classiczcars.com/forums/topic/31588-78-280z-has-trouble-starting-in-hot-weather/#findComment-281289 Share on other sites More sharing options...
April 21, 200915 yr comment_281297 Wow that is close. Cool. Link to comment https://www.classiczcars.com/forums/topic/31588-78-280z-has-trouble-starting-in-hot-weather/#findComment-281297 Share on other sites More sharing options...
