240kconvertible Posted April 22, 2009 Share #1 Posted April 22, 2009 Hi Guys,I'm getting some plates laser cut to be welded to the firewall behind the brake booster and also to the back of the steering column support to offer extra strength.They will fit the new model skyline booster pattern. If any one is interested I can get some made up for them. I'm paying about $55 to get the pattern made and two cut, after that I think they will charge $10 each one they do.The reason I need it is that I forgot the column can be adjusted in the K and when you move mine up it hits the bottom of the booster, as I now have six holes in the firewall (two new ones to mount r34 booster) not 4 and will end up with ten holes when I drill the new 4 to mount the booster higher I figured I better support it properly.Pm me if your keen to get one.Cheers Andrew Link to comment Share on other sites More sharing options...
Disco Bob Posted May 10, 2009 Share #2 Posted May 10, 2009 can you post a pic?Thanks Link to comment Share on other sites More sharing options...
240kconvertible Posted June 14, 2009 Author Share #3 Posted June 14, 2009 Sorry it took me so long I have 5 x 3mm thick plates left at $5 each. I've welded one plate to the firewall and the another plate to the pedal mounting bracket for extra strength. Link to comment Share on other sites More sharing options...
