280ZX Distributor Advance Curve Reference
Walter Moore
Rockauto has both the plugs and the wires.  I don't know about shipping to Greece though.  If you started a new thread about buying parts in Europe, some of the guys from the north would probably have suggestions.
You want plugs for a 1980 280ZX.  Rockauto lists all of the important numbers too, which is nice.
http://www.rockauto.com/
  • 2 years later...
If we're talking about the same thing, this stuff confuses me, my weights are stamped 8.5 so advance is 17 degrees and I have verified this with a full advance setting on my timing light.  At 2,500 rpm my light shows 34 while the pointer and pulley are at zero. The numbers stamped on the body of my dizzy are the '79 specs on Mr Moore's spreadsheet.
He was in an accident and lost his 240 so I don't know how involved he is anymore on this forum.  Maybe he'll see you notification and respond?  I've read on Blue's Tech Tips on recurving the dizzy.  Maybe try and google that.
I'd keep the current dizzy and just set it up how I want.  You can readily adjsut the mechanical adnavce mechanisms and vacuum advance to your engines specific needs.
Read Jason Gray's Distributor article.  Most Nissan  electronic distributors have a fully adjustable Vacuum advance Canister. If it has an Epoxy plug on the end of the vacuum can, you can fully adjust the Vacuum advance.
Under the epoxy plug at the end of the Vacuum diaphragm you will find an inner and outer threaded collar that adjusts spring tension and vacuum arm travel length. Shorten the travel until you have about 20 degrees Vacuum advance. Use a Mighty Vac and a Dial Back timing light to adjust.
Edit: Link to archive of Jason Gray's dizzy FAQ page:
http://web.archive.org/web/20031006095409/http://home.att.net/~jason510/Dizzy_FAQ.htm
Edited by Chickenman
