Posted May 2, 200916 yr comment_282492 Hello all,Last fall I purchased a new set of 5 way adjustable struts with 1" lowering springs from tokico to install on my 77 280z. getting ready to install them this week and have a few questions. First off I'm planning on using the lower spring cups and hardware from the original struts I assume this is ok. It appears as though the lower spring cups are welded in place so i need to break the welds on the old and reweld onto the new. any advise on welding temp or feed rate? (never welded on struts before). Also any measurements on positioning the lower cups on the new struts. do I copy the originals or do i have to compensate for an inch drop? If anyone can give me any help or direct me to a post or website that already exists on this topic would be greatly appreciated. really want to have this thing up and running for the next local scca event. Link to comment https://www.classiczcars.com/forums/topic/31726-tokico-5-way-adjust-struts-on-a-280/ Share on other sites More sharing options...
May 3, 200916 yr comment_282494 You appear to be confused or you're not sharing something with us. Did you buy a complete spring over conversion kit? If not, the Tokico strut "inserts" just slip into the existing strut housing, and the lowering springs sit on the existing spring perch. No cuting or welding required. Link to comment https://www.classiczcars.com/forums/topic/31726-tokico-5-way-adjust-struts-on-a-280/#findComment-282494 Share on other sites More sharing options...
May 3, 200916 yr Author comment_282498 ahh it's an insert. Wow I think I'm an idiot. Please ignore this post and pretend it never happened. Link to comment https://www.classiczcars.com/forums/topic/31726-tokico-5-way-adjust-struts-on-a-280/#findComment-282498 Share on other sites More sharing options...
May 3, 200916 yr comment_282548 No problem. Glad to help. Stick around and do some reading. The search feature will lead you to all the answers you desire, and if not there's plenty of others to help. Link to comment https://www.classiczcars.com/forums/topic/31726-tokico-5-way-adjust-struts-on-a-280/#findComment-282548 Share on other sites More sharing options...
