Posted May 4, 200915 yr comment_282663 Here's a newb question for everyone. I am running a Crane mild street cam in my L24. I found my cam card yesterday and the valve lash specs that are on the card are not the same as the factory hot settings. Which specs are the correct ones to use? Link to comment https://www.classiczcars.com/forums/topic/31748-valve-lash-settings-w-new-cam/ Share on other sites More sharing options...
May 4, 200915 yr comment_282664 Use the specs that cam with the cam. I believe mine suggested setting .002" tighter than stock... Link to comment https://www.classiczcars.com/forums/topic/31748-valve-lash-settings-w-new-cam/#findComment-282664 Share on other sites More sharing options...
May 4, 200915 yr Author comment_282673 Thanks Jon, that is the same for mine. As it was tighter, I wanted to make sure before I made the adjustment. Link to comment https://www.classiczcars.com/forums/topic/31748-valve-lash-settings-w-new-cam/#findComment-282673 Share on other sites More sharing options...
