Posted May 6, 200916 yr comment_282884 I've been searching for a knock in the rear suspension since I put the car back on the road, following the rear diff swap and rear suspension upgrades over the Winter. Checked and double-checked all bolted connections (I thought), re-torqued the bushing connections, re-checked everything brake related that could be loose. I couldn't find anything loose. Then a light went off......I never torqued the passenger side strut retainer nut down all the way (the one inside the rear hatch area). I finger-tightened it when I was re-assembling, and guess I somehow forgot to go back and torque it down. Tightened it up, no more knock....:stupid: Learn from my dumb-assness. Link to comment https://www.classiczcars.com/forums/topic/31780-rear-suspension-know-solvedstupid/ Share on other sites More sharing options...
May 6, 200916 yr comment_282911 Been there and done that. Except mine was the gland nut on the strut cartridge and I was on track.Oops...Tom Link to comment https://www.classiczcars.com/forums/topic/31780-rear-suspension-know-solvedstupid/#findComment-282911 Share on other sites More sharing options...
May 6, 200916 yr comment_282930 Today I had the steering wheel slip 90 degrees as I was driving on the highway (Rt495). I pulled over at the first safe place and checked the steering wheel nut, the coupler and the rack bolts. One wheel had a serious toe in issue so I drove very slowly the remaining 10 miles home.I suspected that the inner tie-rod had gone in my reman rack but it turns out the concentric control arm bushing had slipped because the bolt was loose. Now I just need to get it back to something close to normal and get it re-aligned this week.Bad news - it was the first sunny day in a week. Good news - I didn't wreck my Z.Glad your issue got solved Paul.... Link to comment https://www.classiczcars.com/forums/topic/31780-rear-suspension-know-solvedstupid/#findComment-282930 Share on other sites More sharing options...
May 6, 200916 yr Author comment_282932 gnosez said: Good news - I didn't wreck my Z.Wow, sounds like it could've gone real bad! Glad it all ended up OK.Anyway, 1 last issue to work out, and I'm ready for the Summer. Link to comment https://www.classiczcars.com/forums/topic/31780-rear-suspension-know-solvedstupid/#findComment-282932 Share on other sites More sharing options...
