Posted May 7, 200915 yr comment_282990 so heres a few pics guys. thats what .115 looks like after being bored out Link to comment https://www.classiczcars.com/forums/topic/31790-update-on-the-31-stroker/ Share on other sites More sharing options...
May 7, 200915 yr comment_282996 Good to see actual photos of the process. Did you consider using a torque plate for the boring? Link to comment https://www.classiczcars.com/forums/topic/31790-update-on-the-31-stroker/#findComment-282996 Share on other sites More sharing options...
May 7, 200915 yr comment_282999 Yeah baby!!!! Dead sexy. Can't wait to see your dyno sheet Link to comment https://www.classiczcars.com/forums/topic/31790-update-on-the-31-stroker/#findComment-282999 Share on other sites More sharing options...
May 7, 200915 yr comment_283011 Is it going to be carb'd or FI? Any idea on what cam you are going to use?We just tore down my block to check bearings before putting it in the car and trying to decide if my cam(460 lift and 270 duration) is going to be enough to really work my triple OER 47mm carbs.Tom Link to comment https://www.classiczcars.com/forums/topic/31790-update-on-the-31-stroker/#findComment-283011 Share on other sites More sharing options...
May 7, 200915 yr comment_283012 Zoom! Zoom! Link to comment https://www.classiczcars.com/forums/topic/31790-update-on-the-31-stroker/#findComment-283012 Share on other sites More sharing options...
May 7, 200915 yr Author comment_283014 Good to see actual photos of the process. Did you consider using a torque plate for the boring? i really wanted to but here at the shop we couldnt find one, but it will still work fairly nice it would only be off by a lil shouldnt make a huge diff. and the cam not to sure what im gonna use im trying to see what kind of size carbs i wanna use first and then ill see what kind of cam im gonna use but ill keep you guys updated. next step would be port and polish, and then decide what kind of cam i should run...after carbs of course.. Edited May 7, 200915 yr by FairladyZS30 Link to comment https://www.classiczcars.com/forums/topic/31790-update-on-the-31-stroker/#findComment-283014 Share on other sites More sharing options...
May 7, 200915 yr comment_283016 triple 44mm's are what you need Link to comment https://www.classiczcars.com/forums/topic/31790-update-on-the-31-stroker/#findComment-283016 Share on other sites More sharing options...
May 8, 200915 yr comment_283091 Isky will regrind your existing cam to 3 stages........The advantage is you're using the Japanese compatable metals.You will need springs,retainers.lash pads and new Nissan rockers. www.iskycams.com Link to comment https://www.classiczcars.com/forums/topic/31790-update-on-the-31-stroker/#findComment-283091 Share on other sites More sharing options...
May 9, 200915 yr Author comment_283230 where would i get new nissan rockers? from the factory? hmmm sounds like it would cost me a fortune now haha thanks for the info Link to comment https://www.classiczcars.com/forums/topic/31790-update-on-the-31-stroker/#findComment-283230 Share on other sites More sharing options...
May 11, 200915 yr comment_283333 I just bought a dozen from my local dealer......about $18.00 a piece. Link to comment https://www.classiczcars.com/forums/topic/31790-update-on-the-31-stroker/#findComment-283333 Share on other sites More sharing options...
https://www.classiczcars.com/forums/topic/31790-update-on-the-31-stroker/Share on other sites
