racsov500 Posted May 10, 2009 Share #1 Posted May 10, 2009 hay guys chasing some bits for a project ive gotto suit 2 door c210, good condition partstailshaft (auto and manual are the same yeah?)pair of doors rust free with original locks and latches in good nick.. good luck I know, alternatively a pair of locks and a passenger side latch assemblyboot lid striker (bit on the lid the latch clicks on to)rear drivers side seat beltroof light console thingmanual gear shifter bootheadlight surrounds and grillgood l24 engine with manifolds ect, box and flywheelif you have any of this $^!# laying around let me know. Im not in a huge rush to buy though. I have a L24 engine with a N47 head, oil return on the sump, water line fitting, and a banjo bolt oil line in the sump plug. its had a freshened up head and a new gasket but was blowing smoke apparently.. suit rebuild I spose. has a dizzy with new leads and some other bits hanging off it. no manifolds Link to comment Share on other sites More sharing options...
Mastadd240K Posted May 11, 2009 Share #2 Posted May 11, 2009 Door Locks are still available from nissan, and i believe they can even supply the ones that belong to your car with A new Key, They need your Vin or Key No. I think 180B sedan/Coupe Rear seat Belts are the Same.And head light Surrounds? the ones that clip the actual round Semi Sealed Fittings in? the Aluminum Ones? I have some 240k c110 ones, brand new..... They may suit but not shore Link to comment Share on other sites More sharing options...
racsov500 Posted May 11, 2009 Author Share #3 Posted May 11, 2009 interesting about the locks.. will look into it. but the holes for the locks on the doors are half fecked cause someone has tried and failed to fit aftermarket locks. but the passenger side latch is broken and the shells are rusty in the corners so its going to be easier to find a better pair of doors headlight surrounds are separate from the grill on c210.. look like this. Link to comment Share on other sites More sharing options...
Mastadd240K Posted May 11, 2009 Share #4 Posted May 11, 2009 Ahhhh i have a Set of those, in white tho, otherwise mint, they may be reproduction tho, under them there will be the Stainless steel Brackets i was talking about. ill take picture and show you Link to comment Share on other sites More sharing options...
matt240K Posted May 12, 2009 Share #5 Posted May 12, 2009 Your profile doesn't say where you are, but If you're in sydney try Carlos Casmiri at sportsclassic. I spoke with him this morning and he mentioned that he either had or was about to get a C210 Coupe. Link to comment Share on other sites More sharing options...
