Posted May 12, 200915 yr comment_283495 I had not seen this done this way so I thought I would share what I did. I needed a way to mount 3 switches somewhere but I did not want to put a new hole in my console. My rear defroster did not work so I had that switch space plus the empty spot next to it to use. Looking for a way to make it look as natural as I could I wanted to use something that matched the texture of the console. I had a few extra covers for the rear of the console and saw that it would fit with just a bit of trimming of the console. Next job was to find switches that will fit. I bought the switches from Delcity, www.delcity.com, no reason other then variety and ease of ordering. I needed a SPST On-Off for the driving lights, a SPST Mom-Off for water pump and a SPDT Mom-Off-Mom to control the antenna. Delcity had all 3 that matched. I spaced out the holes, drilled and mounted. It fits well and works for my needs. Hope this might help someone. Link to comment https://www.classiczcars.com/forums/topic/31842-mounting-switches-on-console/ Share on other sites More sharing options...
May 12, 200915 yr comment_283534 Nice clean look!Dennis Link to comment https://www.classiczcars.com/forums/topic/31842-mounting-switches-on-console/#findComment-283534 Share on other sites More sharing options...
May 13, 200915 yr comment_283550 Thats nice, but no indicator lights? Link to comment https://www.classiczcars.com/forums/topic/31842-mounting-switches-on-console/#findComment-283550 Share on other sites More sharing options...
May 13, 200915 yr comment_283562 I had not seen this done this way so I thought I would share what I did.I needed a way to mount 3 switches somewhere but I did not want to put a new hole in my console. My rear defroster did not work so I had that switch space plus the empty spot next to it to use. Looking for a way to make it look as natural as I could I wanted to use something that matched the texture of the console. ...While I like what you did, given your desire to make it look natural, why didn't you just some original switches for another purpose?Will Link to comment https://www.classiczcars.com/forums/topic/31842-mounting-switches-on-console/#findComment-283562 Share on other sites More sharing options...
