Email logins are now active ×
Driveshaft came apart
Well, I have been trying to figure out for the longest time what the heavy vibration my car does at any speed above 35mph. I balance the tires etc. The balancing helped a little. But after last monday I think I know the culprit.
Anyway, long story short I was on the interstate driving and then boom I hear this long rattle and after words I run over several metal pieces. I pull over immediately and check underneath. I see my exhaust pipe hanginf kind low so i figured it fell apart. I call AAA car gets on the tow truck and the driver points out that it is not the exhaust its the driveshaft thats hanging down.
Evidently the 4 bolts came out that connects it to the differential yoke. My question is is there anything else that I should check/replace when putting the bolts back in?
My dad says I need new U joints as well, but the joints are only in the front of the shaft according to my haynes manual. Any help is welcomed. Also should i get the driveshaft rebalanced since it hit the street?
Pictures will be posted tmrw.
Pics.
Damage done (dented my exhaust pipe):
Passenger side (knocked my bracket loose):
Rear (broke my rear bracket):
As for the rear should I take it to a muffler shop to get the bracket replaced? I have twice pipe (I think) it was on the car when I bought it. Not sure where to get that bracket piece from.
Edited by KenshinX
Nevermind.
Got it fixed. Now I need to get the exhaust brackets replaced. I'll try to do it myself If not I'll get a friend who owns a muffler shop to do it. The main brackets are sold at pep boys for relatively cheap. Thanks everyone for the input really. :)
Edited by KenshinX
  • Who's Online   1 Member, 0 Anonymous, 309 Guests (See full list)
