Do a quick ring around Menzies Metals and other Bulk Metal merchanants just in chase someone saw it there and traded it for a quick $300 worth of steel. You never know. Ring up some local car collectors and find out where they take the cars for recycling.
Good luck & be Quick !!!
My new number plates "QWIK"
you need to run a 2.5mm tip and needle kit in your gun, Dave ( my brother) says he ran our gun at 40-45 psi. Again we used the same epoxy thinned down as an etch........
What brand and type of epoxy and hi fill did you use? can i also ask.. when you epoxied the car, how did the paint look immediately after spraying?
I just sprayed my bonnet and bootlid with Dupont 840R the week before last.. but i don't think i had the gun set properly.. i expected the epoxy to look shiny and almost like a plastic coat.. but instead it looks more like a primer out of a can (i think i had the fluid down too much and it dried before hitting the paint)
i am trying to work out if the epoxy should look like a wet pool when applying
The House of Kolor, and PPG epoxy primers both come out matt like normal primers, once dry. I have seen the shinny primers, they are gaining popularity as you can see dents easier but dont assume because its epoxy it will be shinny. When applying; primers are shinny then they dry matt, id say you where to dry on the coats if you couldnt achieve a wet look before the paint flashed and dried.
Cheers
Edited by s13drifter
Definately interested in the trims, I have a good mate in Dandenong that you can send the parts to, Trevor Davis auto refinishers, will get a street address we can work out something for sure as someone is down there every few weeks as Trev paints all our rods and cars.
