The House of Kolor, and PPG epoxy primers both come out matt like normal primers, once dry. I have seen the shinny primers, they are gaining popularity as you can see dents easier but dont assume because its epoxy it will be shinny. When applying; primers are shinny then they dry matt, id say you where to dry on the coats if you couldnt achieve a wet look before the paint flashed and dried.
Cheers
Checked on the weekend, and it actually seems to have come out quite well (maybe a little on the thin side, but certainly better than a normal primer finish).. i did a bit more (engine bay, doors and roof) over the weekend and keeping the gun a lot closer and putting down a lot more paint "seems" even better (few runs where the hose got snagged.. oops)
sorry for the hijack :)
  • 4 weeks later...
  • 1 month later...
  • 4 weeks later...
