Transmission Troubles, or rear end?
Seanh
Yeah, got it back on there and all is solved, car sounds great now. Well, except for my rear end mount thats clunking all the time, but that will get fixed soon enough. I jacked the rear end up pretty high, so tranny fluid wouldn't run out, so that wasn't a problem. I'v already had my nasty experiences with that stuff on my friends 280z. I just changed the fluid about a week ago, thinking perhaps it was low and that was causing my shifting noises, found out it was pretty low, but I drained it all and refilled it with new synthetic 80-90 gear oil. Thanks for all the help!
I made a simple bracket that prevents the front
differential mount from moving around. It also
ends any possibility of breaking the mount.
<a href="http://12.224.138.56:8884/Files/Datsun/LSD-Brace/Diff-Mount.htm">Click Here!</a>
