Posted May 21, 200916 yr comment_284351 My name is Gary. I have a 1973 240Z I just took out of storage and brought to Florida. It runs well, has 48,000 miles on it. I had it serviced including drain the gas tank and put fresh, clean the plugs, flush the radiator and bleed the clutch. My problem is there is a strong smell of raw gasoline in the cabin. Nothing is dripping or leaking and there is no smell of gasoline outside the cabin. There is no gas smell in the carpets from shoes. The service tech said, if the gas cap is not on correctly the cabin will smell, but the cap is on correctly. Anyone have any ideas? Help…… Link to comment https://www.classiczcars.com/forums/topic/31935-gas-smell/ Share on other sites More sharing options...
May 21, 200916 yr comment_284352 probably the evaporator tank. if you do a search on it theres write ups on removing it Link to comment https://www.classiczcars.com/forums/topic/31935-gas-smell/#findComment-284352 Share on other sites More sharing options...
May 21, 200916 yr Author comment_284357 What is it? are you talking about the reserve tank? Link to comment https://www.classiczcars.com/forums/topic/31935-gas-smell/#findComment-284357 Share on other sites More sharing options...
May 21, 200916 yr comment_284360 what ever its called it sit behind a panel in the back behind the passenger quarter window Link to comment https://www.classiczcars.com/forums/topic/31935-gas-smell/#findComment-284360 Share on other sites More sharing options...
May 21, 200916 yr comment_284361 Try the search function. http://www.classiczcars.com/forums/search.php?searchid=744663This has been covered many times before and there are lots of different suggestions. Link to comment https://www.classiczcars.com/forums/topic/31935-gas-smell/#findComment-284361 Share on other sites More sharing options...
May 22, 200916 yr Author comment_284460 How do I get here, no search was found with that number 74463???Help Link to comment https://www.classiczcars.com/forums/topic/31935-gas-smell/#findComment-284460 Share on other sites More sharing options...
May 22, 200916 yr comment_284461 just go to http://www.classiczcars.com/forums/forumdisplay.php?f=2 and search "vapor tank" or "gas smell" there is no one thread on this subject but multiple threads it because it can be one of many issues by searching using those key words you my find the thread that has your fix,but you should start by inspecting all your hoses. try hunting down a 73 240z FSM Edited May 22, 200916 yr by overdrivex Link to comment https://www.classiczcars.com/forums/topic/31935-gas-smell/#findComment-284461 Share on other sites More sharing options...
May 22, 200916 yr comment_284462 One of the most common questions about Z's. You could fill volumes with the amount of info about fixing the gas fumes issue. On this board and others. Fixes range from lengthening your tailpipe, to sealing your hatch, to adjusting your floats. Try a couple of search terms and you'll find all kinds of possible solutions.Good luck! Link to comment https://www.classiczcars.com/forums/topic/31935-gas-smell/#findComment-284462 Share on other sites More sharing options...
May 23, 200916 yr comment_284490 gcohen said: How do I get here, no search was found with that number 74463???HelpJust go to the top of the page and in the header you will find Search. Click on it and follow the pomps. Look under evap tank, or gas fumes . the evaporation tank is on the passenger side behind the trim panel to the rear of the tire. There are several hoses that connect to it and the gas tank and fill hose. Most likely one or more of these are cracked and leaking fumes. I showed a member named dogma how to do away with the thing a few years ago and he wrote an article on it. If you decide to remove and do away with the tank and cannot find the info . send me a PM (private message) and I will help you. Gary Link to comment https://www.classiczcars.com/forums/topic/31935-gas-smell/#findComment-284490 Share on other sites More sharing options...
May 23, 200916 yr comment_284491 gcohen said: How do I get here, no search was found with that number 74463???HelpI did a search for "gas fumes" and it gave me the link I originally posted. I guess the search results don't stay active for very long, but if you do a similar search you will find lots of information about this. Like others have said, it may be a cracked hose or air gaps that you need to seal up.-Mike Link to comment https://www.classiczcars.com/forums/topic/31935-gas-smell/#findComment-284491 Share on other sites More sharing options...
May 23, 200916 yr comment_284518 This thread got me to use the search feature to find out why when I fill my 73 I get a leak....but only when the tank is full after I burn off a gallon or two it no longer leaks. I could not find any former talks of that using the search....it also leads to fumes in the car too of course. I seems to be leaking from the top of the tank and not any of the sides. Opinions? or shoud I search with the search feature more? Or did I just high jack? Link to comment https://www.classiczcars.com/forums/topic/31935-gas-smell/#findComment-284518 Share on other sites More sharing options...
May 23, 200916 yr comment_284522 This link also provides other links to some good info.http://www.classiczcars.com/forums/showthread.php?p=217164&highlight=filler+tube+leak#post217164 Link to comment https://www.classiczcars.com/forums/topic/31935-gas-smell/#findComment-284522 Share on other sites More sharing options...
