Posted May 23, 200915 yr comment_284548 Just purchased a NOS set of Mulholland rear strut cartridges. Went with these because I was hoping to maintain stock ride height without cutting the coil springs. However, the gland nut used with the stock struts will not work with the Mulhollands as the gland nut is too thick. I am now of the opinion that the gland nut is specific to the cartridge and the NOS Mulhollands did not come with gland nuts. I know it's a long shot, but does anyone out there know where I might find the gland nut I need? The new cartridges are P/N 2351502. Thanks in advance. Link to comment https://www.classiczcars.com/forums/topic/31953-gland-nut-for-mulholland-rear-strut-cartridges/ Share on other sites More sharing options...
May 24, 200915 yr comment_284607 Most likely a Tokico gland nut will work. Koni also makes gland nuts in both sizes for the S30. Link to comment https://www.classiczcars.com/forums/topic/31953-gland-nut-for-mulholland-rear-strut-cartridges/#findComment-284607 Share on other sites More sharing options...
May 24, 200915 yr Author comment_284613 Thanks John. Anyone out there have a couple of these they'd part with for a few bucks plus shipping? Link to comment https://www.classiczcars.com/forums/topic/31953-gland-nut-for-mulholland-rear-strut-cartridges/#findComment-284613 Share on other sites More sharing options...
May 25, 200915 yr comment_284645 Tony,I am not sure where they are at, but I know that I have two gland nuts for Mullholland that I removed from one of my parts cars. I will look and see if I can find them. I was suprised to find Mullholland inserts. What size (diameter) is the shaft of the Mullholland insert. That will help me as I have OEM, Bilstein, and other gland nuts that I have removed form parts cars. I also think you will find that the shaft diameter is the same as the Tokico (or nearly the same).Paul Link to comment https://www.classiczcars.com/forums/topic/31953-gland-nut-for-mulholland-rear-strut-cartridges/#findComment-284645 Share on other sites More sharing options...
May 25, 200915 yr Author comment_284654 The portion that tapers off near the end and fits in the gland nut measures about 1.63" (~41.4mm). Thanks again. Link to comment https://www.classiczcars.com/forums/topic/31953-gland-nut-for-mulholland-rear-strut-cartridges/#findComment-284654 Share on other sites More sharing options...
May 25, 200915 yr comment_284655 I knew I should have saved those nuts when I tossed my old Mulhollands..........There's a possiblity that I actualy did but I have no idea where they'd be at this point. I'll go digging if you're unsuccessful, however I'll be out of town until the first or second week of June so consider me a last resort. Link to comment https://www.classiczcars.com/forums/topic/31953-gland-nut-for-mulholland-rear-strut-cartridges/#findComment-284655 Share on other sites More sharing options...
May 28, 200915 yr comment_284955 Hey Tony, No go from me. I looked high and low but did not find any with the right dimension. I did find one that the shaft collar opening was more oval than round though Sorry, Paul Link to comment https://www.classiczcars.com/forums/topic/31953-gland-nut-for-mulholland-rear-strut-cartridges/#findComment-284955 Share on other sites More sharing options...
May 29, 200915 yr Author comment_284986 No worries. I certainly appreciate the effort. I have two more sets of front and rear suspension. I'll probably disassemble those in the hopes that I'll find the right gland nuts. If not, I'll just take a different route on the struts. Thanks again for looking.Tony Link to comment https://www.classiczcars.com/forums/topic/31953-gland-nut-for-mulholland-rear-strut-cartridges/#findComment-284986 Share on other sites More sharing options...
May 29, 200915 yr comment_284992 I know someone who might have a spare pair, I sold him 1 1/2 sets of Mullhollands a while back. Can't recall if there were any extra gland nuts in the lot or not. I'll shoot him an email. Link to comment https://www.classiczcars.com/forums/topic/31953-gland-nut-for-mulholland-rear-strut-cartridges/#findComment-284992 Share on other sites More sharing options...
May 31, 200915 yr comment_285238 I know I have a set of Mullhollands in my garage. I walk past them on the shelf every time I go in. I'm pretty sure I have the gland nuts on them. If they are there you'll just have to pay for shipping from Moncton, NB, Canada. I can always machine some if I ever wish to use the inserts.I'll check in a few hours and let you know. Edited May 31, 200915 yr by Jeffrey Link to comment https://www.classiczcars.com/forums/topic/31953-gland-nut-for-mulholland-rear-strut-cartridges/#findComment-285238 Share on other sites More sharing options...
May 31, 200915 yr Author comment_285252 I'll gladly pay the shipping if you have them and are willing to part with them. Let me know. Thanks. Link to comment https://www.classiczcars.com/forums/topic/31953-gland-nut-for-mulholland-rear-strut-cartridges/#findComment-285252 Share on other sites More sharing options...
May 31, 200915 yr comment_285254 I found three in the garage. Just to be sure these are Mullholland strut inserts that came out of a 240z. The inserts are orange and are probably 80's vintage. Here is a picture. So you only need two? Send me your mailing address I'll get them off to you tomorrow. Jeffrey Link to comment https://www.classiczcars.com/forums/topic/31953-gland-nut-for-mulholland-rear-strut-cartridges/#findComment-285254 Share on other sites More sharing options...
