Perhaps DeskTop Screen's could all be put in one Directory or File...so they could be located and downloaded as a group. We've had a lot of really great images Posted throughout several Threads..
Just a thought..
FWIW,
Carl B.
Carl,
That's a very good idea. Would love to make a rotating image 240Z screensaver.
I'd re-post these and perhaps one or two others in a slightly larger format, say 1920 x 1080 to provide better resolution for those with HD monitors.
There has been a dedicated spot for Wallpaper here on CZCC since 2003. It is called (appropriately enough) Wallpapers, and is in the Downloads section. Here is a direct link: Wallpapers
As some noted, for best use, try to upload them in hi-res. Most computers can downsize wallpaper nicely, but stretching a small image to cover today's larger screens often gives less pleasing results.
Thanks Chris!!! I don't want to intrude on the Z desktop thread w. 510 images :)
You can see my photo sets here. Click on the 510 set and you can see hundreds of photos. My dad's Z collection and his current 71 resto are on there along with my BMW build.
http://www.flickr.com/photos/14049800@N00/sets/
This is my project build on the 510 forum as well.
http://www.the510realm.com/viewtopic.php?f=27&t=9231
"IF" that's a VZ decal in the quarter window.
"IF" - if the hub caps on that Z are correct for that car - then it would be a 71 Model Year. "IF" that is the case it could be one of our missing Vintage Z's... HLS30 23537. That or it is a picture of HLS30 40904 before or after the pictures with the slotted mags. I don't recall seeing a front license plate like that on 40904....
The only "Red" 1971 VZ that we know of is #40904 and the only 1971 VZ still missing is #23537.
FWIW,
Carl B.
