some questions about cylinder heads and my block
E31, E88, N47, P90 = Square port
N47, P79 = Round port
Those are just the most common heads from the U.S.
You mean:
E31, E88, N42, P90, P90a = Square port
Also, if the head is original to the '83 and it is in deed a P90 variety it's going to be a P90a. What's the difference you ask? I'm glad you asked...the P90a has hydrolic lifters. From everything I have ever read you do not want the hydrolic lifters. Do a search on this topic and you should find plenty of reading material to keep you busy for a while. ;)
Also for what it's worth there were two different versions of the E88 head made, I believe that the better version was original to the '71 and '72 cars while the less desireable one came on the '73 cars. Again, do a search on this topic and you'll find more detailed info.
One good resource is Bryan Little's Z Garage site: http://datsunzgarage.com/
Edited by texasz
after angsting over this for weeks, i've finally decided to just buy a well-rebuilt N42. no fuss, no muss, and i'll never have to worry about it again. thanks for all yall's input. i really appreciate it.
  • Who's Online   2 Members, 0 Anonymous, 269 Guests (See full list)
