Ok went to change thermostate and snapped off one bolt, after soaking with PB for 10 days.
? i have is what size is the bolts?
Is there a list of bolt specs for the 72-240Z?
What are all the abbreviations being used on the forum?
Thxs in advance,
Joel
https://www.classiczcars.com/forums/topic/32055-thermostate-bolts/
My thermostat bolts snapped off as well. I tried using an easy-out, but broke it off as well. I ended up having to VERY CAREFULLY drill out the bolt.
A harrowing thing too, drilling a steel bolt out of an aluminum housing... I just keep drilling into it with ever larger drills until the bolt literally unpeeled from the housing. One mistake and you will need a new housing.
At least I think they are still available if you mess it up.
Motorsports sells the bolt kit for the thermostat housing.
I used the MSA ones and they worked out fine, they're on the
cylinder head now.
Dont know how long untill they go bad though like the old ones did when
those snaped off too on my '77.
Didn't know it was a common problem.
~Z~
Just what I want to hear when I plan to do my water pump in the near future. I have a friend I know very well who has his own shop that he runs and has a real nice facility with more high end equipment than I do at my house. I'm kicking the idea around to just outsource this particular job to him being that mine has the orig. 32 yr. old parts, I can just see those damn bolts going "SNAP" on me :paranoid: I wish I had time to do it where I work but hell I'm lucky if I get a lunch break sometimes I'm so busy with customer stuff.
Water pump bolts are another thing entirely different from the thermostat housing bolts. It is hell having one snap off. If I had it to do over again, I would have outsourced the job knowing one or two would snap off in the block and the chore, and I mean CHORE, would become someone else's responsibility. I broke easy outs in the block and it took many hours to drill it out and I wound up having to use a helicoil.
Yeah, I bassicaly had to buy NOS lower and upper thermostat housing parts
and the bolts.
The bolts that broke were in the lower housing.
Figured why drill when I can just replace the whole thing since the
lower housing to cylinder head bolts didn't brake off.
Easy job for me :beer: , though cost me 100 bucks LOL
~Z~
and the bolts.
~Z~
Like me and rtaylor were saying though, having a bolt or bolts snap off for the water pump is a different story. Trying to deal with a problem like that out of your home garage where your equipment is limited and your busy working everyday of the week at your job, it just turns into a major nightmare and not really worth the hassel. My two cents. :)
Edited by DatsunZsRule
