Posted June 3, 200915 yr comment_285505 I Have new factory Nissan hardware kits that I bought a while back ago that comes with the anti squeel springs and shims and wanted to get new calipers for it now and Courtesy Nissan E-mails me today "Dear Jared, Sorry the calipers for your car are no longer available through Nissan" So now I suppose I have to go aftermarket on those and I'm sure the hardware kit won't work in the aftermarket ones Never fails :classic: Link to comment https://www.classiczcars.com/forums/topic/32066-brake-calipers-no-longer-avail-through-nissan/ Share on other sites More sharing options...
June 3, 200915 yr comment_285506 No real reason to believe that they won't work... most likely the same as OEM...Worth a try... Link to comment https://www.classiczcars.com/forums/topic/32066-brake-calipers-no-longer-avail-through-nissan/#findComment-285506 Share on other sites More sharing options...
June 3, 200915 yr Author comment_285507 Hopefully they will. Maybe it's just me but the aftermarket ones I saw looked slightly different. Could be just me too. Can't trust pictures. Link to comment https://www.classiczcars.com/forums/topic/32066-brake-calipers-no-longer-avail-through-nissan/#findComment-285507 Share on other sites More sharing options...
June 3, 200915 yr comment_285509 Do the pads, shims and springs look like these ?? Link to comment https://www.classiczcars.com/forums/topic/32066-brake-calipers-no-longer-avail-through-nissan/#findComment-285509 Share on other sites More sharing options...
June 3, 200915 yr comment_285511 Try this photo --- Link to comment https://www.classiczcars.com/forums/topic/32066-brake-calipers-no-longer-avail-through-nissan/#findComment-285511 Share on other sites More sharing options...
June 3, 200915 yr Author comment_285516 I havent actually pulled mine off yet but looking at the FSM for my 280Z, they look different from the ones you posted. I'll know more when I have a chance to work on it while I'm off from work on vacation. Link to comment https://www.classiczcars.com/forums/topic/32066-brake-calipers-no-longer-avail-through-nissan/#findComment-285516 Share on other sites More sharing options...
June 3, 200915 yr comment_285518 Huh? Nissan doesn't sell calipers for s30's anymore??! Currently I have some reman calipers on my Z and they SUCK. The pistons have no plating which is why I get 2-3 years out of a set. I was hoping to buy some real calipers from nissan. Jim Link to comment https://www.classiczcars.com/forums/topic/32066-brake-calipers-no-longer-avail-through-nissan/#findComment-285518 Share on other sites More sharing options...
June 3, 200915 yr Author comment_285523 Huh? Nissan doesn't sell calipers for s30's anymore??! Currently I have some reman calipers on my Z and they SUCK. The pistons have no plating which is why I get 2-3 years out of a set. I was hoping to buy some real calipers from nissan. Jim I too was very bummed out. I don't like "Aftermarket" :disappoin Link to comment https://www.classiczcars.com/forums/topic/32066-brake-calipers-no-longer-avail-through-nissan/#findComment-285523 Share on other sites More sharing options...
June 3, 200915 yr comment_285524 Try this photo ---Not Certain - but those look like the pads from the MK-65, four piston calipers..Are you sure they are for a stock 280Z?FWIW,Carl B. Link to comment https://www.classiczcars.com/forums/topic/32066-brake-calipers-no-longer-avail-through-nissan/#findComment-285524 Share on other sites More sharing options...
June 3, 200915 yr Author comment_285525 Ok, just took some photos of my new factory pads and hardware Kit. Link to comment https://www.classiczcars.com/forums/topic/32066-brake-calipers-no-longer-avail-through-nissan/#findComment-285525 Share on other sites More sharing options...
June 3, 200915 yr Author comment_285526 Are you sure they are for a stock 280Z?FWIW, Carl B. Me?? Yep Original Girling Sumitomo Link to comment https://www.classiczcars.com/forums/topic/32066-brake-calipers-no-longer-avail-through-nissan/#findComment-285526 Share on other sites More sharing options...
June 3, 200915 yr comment_285528 Carl: Yes -- Those are for the FIA 4 piston calipers -- I thought he might have a set -- When I heard him state that Nissan no longer stocks "stock" calipers ..I figured maybe he had a set for my Scarab Always looking Link to comment https://www.classiczcars.com/forums/topic/32066-brake-calipers-no-longer-avail-through-nissan/#findComment-285528 Share on other sites More sharing options...
