May 18, 201014 yr comment_320182 Try spraying a little PBlaster, Kroil, Liquid Wrench or similar on the connection.Let it soak a while.Then maybe a hammer and chisel or other tapered tool to force the connection apart. Link to comment https://www.classiczcars.com/forums/topic/32081-wrong-driveshaft/?&page=2#findComment-320182 Share on other sites More sharing options...
May 20, 201014 yr Author comment_320323 I managed to get it off of there yesterday. I flipped the rear diff mount, bolted the rear end back in, set the parking brake, and gently popped it into reverse. That little amount of twist was just enough to break whatever tension was holding it together. I am removing the powder coating from the flange and that should make it a little less tight for next time. Having the diff set back the right amount makes driveshaft removal much easier.Oh, and open exhaust is ridiculous loud on these things! Link to comment https://www.classiczcars.com/forums/topic/32081-wrong-driveshaft/?&page=2#findComment-320323 Share on other sites More sharing options...
May 20, 201014 yr comment_320378 i have a driveshaft from a '71 240z 4 spd that measures 27" from the end of the spline to the flange(complete length) let me know if you need it Link to comment https://www.classiczcars.com/forums/topic/32081-wrong-driveshaft/?&page=2#findComment-320378 Share on other sites More sharing options...
May 21, 201014 yr comment_320395 Hogie-Before you put that driveshaft back in it would be a perfect time to put a R/T mount in.........do a search. One of the best mods we can do for our cars! Link to comment https://www.classiczcars.com/forums/topic/32081-wrong-driveshaft/?&page=2#findComment-320395 Share on other sites More sharing options...
May 24, 201014 yr Author comment_320666 I finally got everything apart and noticed a couple of odd things. With no driveshaft 1-5 is perfectly smooth with no pop out in overdrive. Since everthing seemed smooth I tossed the driveshaft back in with the differential installed in the proper set-back position and now 1-4 runs good down the road, but 5th still pops out as soon as I let the clutch out. I would be all about an RT mount, though the mount I have now appears to be almost never driven on. I do have a drive line clunk when getting off the gas in 1st and 2nd. There is no slop in the u-joints and the mount is good so I am not sure where it is coming from.Who thinks I will miss overdrive? Link to comment https://www.classiczcars.com/forums/topic/32081-wrong-driveshaft/?&page=2#findComment-320666 Share on other sites More sharing options...
