Posted June 4, 200915 yr comment_285685 Im just curious and dumb about this question that I like to ask..Does the L28 engine fit with the SU carb manifold? I know it seems like its the same engine from L26 and L28 but do they bolt up...I really appologize for this question but I need to know Link to comment https://www.classiczcars.com/forums/topic/32092-su-carb-manifold-stupid-question/ Share on other sites More sharing options...
June 4, 200915 yr comment_285687 Yes.. Link to comment https://www.classiczcars.com/forums/topic/32092-su-carb-manifold-stupid-question/#findComment-285687 Share on other sites More sharing options...
June 6, 200915 yr comment_285926 Most all the engine parts from 1970-1983 (240Z, 260Z, 280Z, 280ZX) are interchangeable. There are some obvious exceptions such as pistons since they are of differing sizes, etc. Though this is not written in stone since you can alway bore a block for larger pistons.In short to answer your question, yes you can do this. Link to comment https://www.classiczcars.com/forums/topic/32092-su-carb-manifold-stupid-question/#findComment-285926 Share on other sites More sharing options...
June 11, 200915 yr comment_286333 Im just curious and dumb about this question that I like to ask..Does the L28 engine fit with the SU carb manifold? I know it seems like its the same engine from L26 and L28 but do they bolt up...I really appologize for this question but I need to knowthats what I did l28 engine and e46 manaflod off of a 1971 Link to comment https://www.classiczcars.com/forums/topic/32092-su-carb-manifold-stupid-question/#findComment-286333 Share on other sites More sharing options...
June 11, 200915 yr comment_286336 Yes, but depending on the intake/exhaust manifold you use, it may have to be modified so you can use the carb mounting holes. Link to comment https://www.classiczcars.com/forums/topic/32092-su-carb-manifold-stupid-question/#findComment-286336 Share on other sites More sharing options...
