June 10, 200915 yr comment_286301 If you live in a Hot weather area, they will fall apart without that clip holding it together. I broke the clps on mine, but didn't want anything "obvious" showing on the exterior. I counter-sunk the hole in the lens and used a wide, flat head machine screw to replace the pin. Then put the chrome strip over the top. (This was while the lens was dis-assembled).Assembled the lens to the rear body with sealant and used a small nut on the back as the "safety" retainer. Link to comment https://www.classiczcars.com/forums/topic/32138-restoringdisassembling-240z-tail-lights/?&page=2#findComment-286301 Share on other sites More sharing options...
June 10, 200915 yr comment_286302 I ran mine through the dish washer. They came apart easily after a hot scrubbing wash. Link to comment https://www.classiczcars.com/forums/topic/32138-restoringdisassembling-240z-tail-lights/?&page=2#findComment-286302 Share on other sites More sharing options...
June 10, 200915 yr comment_286307 I broke the clps on mine, but didn't want anything "obvious" showing on the exterior. I counter-sunk the hole in the lens and used a wide, flat head machine screw to replace the pin. Then put the chrome strip over the top. (This was while the lens was dis-assembled).Assembled the lens to the rear body with sealant and used a small nut on the back as the "safety" retainer.That's actually a pretty good idea, I'll keep it in mind for the next set I do. Link to comment https://www.classiczcars.com/forums/topic/32138-restoringdisassembling-240z-tail-lights/?&page=2#findComment-286307 Share on other sites More sharing options...
June 13, 200915 yr Author comment_286579 What brand of adhesive/sealant would you guys recommend for reattaching the lenses to the bodies? Also, do the rubber pads that were between the lens and the body have to be there when the lights are sealed back together? because the rubber pieces on mine were wasted so I threw them out. I'm assuming a thick blob of some type of adhesive/sealant can replace those couple rubber pieces. Link to comment https://www.classiczcars.com/forums/topic/32138-restoringdisassembling-240z-tail-lights/?&page=2#findComment-286579 Share on other sites More sharing options...
June 13, 200915 yr Author comment_286629 Anyone have any recommendations? Link to comment https://www.classiczcars.com/forums/topic/32138-restoringdisassembling-240z-tail-lights/?&page=2#findComment-286629 Share on other sites More sharing options...
June 13, 200915 yr comment_286639 I just used some silicone adhesive I got at the hardware store. It was the same kind of stuff you use to seal the insides of aquariums. Link to comment https://www.classiczcars.com/forums/topic/32138-restoringdisassembling-240z-tail-lights/?&page=2#findComment-286639 Share on other sites More sharing options...
June 1, 201311 yr comment_424656 hello,this is an old thread, but bestine ( available at art supply stores ) will take off any adhesive without harming plastic.thanks,Ken Link to comment https://www.classiczcars.com/forums/topic/32138-restoringdisassembling-240z-tail-lights/?&page=2#findComment-424656 Share on other sites More sharing options...
