December 30, 201410 yr comment_460960 Did you order overnight shipping? That's a decent company, I'm sure they don't bloat the shipping costs. The owner's name is Oliver and he's a member of the forum. Link to comment https://www.classiczcars.com/forums/topic/32183-mainshaft-nut-source/?&page=2#findComment-460960 Share on other sites More sharing options...
December 31, 201410 yr comment_461023 just glad to get the nut, cost no object - that $26 shipping option was the lowest they offered. .... overnite would have been double we are a captive consumer audience when it comes to obsolete parts ... so it goes - (the joys of fixing obsolete old cars) ("if ya can't afford it, ya shouldn't own it...) Did you order overnight shipping? That's a decent company, I'm sure they don't bloat the shipping costs. The owner's name is Oliver and he's a member of the forum. Link to comment https://www.classiczcars.com/forums/topic/32183-mainshaft-nut-source/?&page=2#findComment-461023 Share on other sites More sharing options...
December 31, 201410 yr comment_461027 That doesn't seem right at all. It's just a nut, it doesn't weigh much. Did you talk to them by phone or just order through the web site? I ordered some window seals by phone and shipping was very reasonable. I hope they're not going to the dark side. Anyway, glad you have the part coming and hope it works out. Link to comment https://www.classiczcars.com/forums/topic/32183-mainshaft-nut-source/?&page=2#findComment-461027 Share on other sites More sharing options...
January 1, 201510 yr comment_461111 Sounds like he charged you shipping to Europe. $75 for a rh nut is a lot. Nissan parts zone still quote it as being available, but that could change when you order it. There is a thread here with a member that ordered the LH thread nut and got a RH nut. Maybe he still has it. I made a screen shot two years ago (left attachment). They were all available then, but now only the 32354-E9804 is "available" in right attachment. Chas Link to comment https://www.classiczcars.com/forums/topic/32183-mainshaft-nut-source/?&page=2#findComment-461111 Share on other sites More sharing options...
January 3, 201510 yr comment_461220 - just alerting everyone to the simple facts of rebuilding our old boxes the bearing kit (56mm counter) is available from O'Reilly's - about $150 - BK104 - includes pocket brg, gskts & seals - a great deal - and all japan brgs npz - say they are removing the RH nut fom web catalog meanwhile - i think i have a solution to re-using an old RH nut if that becomes only option - (add a thin shim just in front & that will index it to a different staking spot) - and use red loctite Z Specialties1 x Nut (Stake) Mainshaft 77-80 5-speed Non Turbo RH (40115-NPDT) = $49.95Sub-Total: $49.95United Parcel Service (XML) (1 pkg x 3 lbs total) (UPS Ground): $26.09Total: $76.04 Link to comment https://www.classiczcars.com/forums/topic/32183-mainshaft-nut-source/?&page=2#findComment-461220 Share on other sites More sharing options...
January 14, 201510 yr comment_461807 Z specialties found the part !!! QUOTE: 1-15-2015 email "The box containing all of my new transmission parts was still packed away from my move earlier this year and I've had to do some digging to find it. I finally found it over the weekend and went through it all. I've been looking for it for the last couple of months. My database showed that I only had one nut left and after going through everything I found out that I had 5 so that was more good news. I dropped your order off at the post office today" p.s - also issued a partial refund on shipping - Link to comment https://www.classiczcars.com/forums/topic/32183-mainshaft-nut-source/?&page=2#findComment-461807 Share on other sites More sharing options...
January 14, 201510 yr comment_461812 yahoo japan auctions. I just emailed a guy in tokyo that sells alot of nos early s30z parts to see if he can get some.lets see what he can come up with. Can't you reuse an old one and stake it? Link to comment https://www.classiczcars.com/forums/topic/32183-mainshaft-nut-source/?&page=2#findComment-461812 Share on other sites More sharing options...
January 15, 201510 yr comment_461876 1-15-2015: Z specialties found the part !!! see post #18 - updated above - i re-torqued the old nut to see where it indexed - = exactly the same position where i had to drill out the prior staking - so no joy today i bought a 3/4 ID flat washer (OD about same as thrust washer) - i will drill it out to fit the shaft - that should let me index the old nut in a stake-able position Link to comment https://www.classiczcars.com/forums/topic/32183-mainshaft-nut-source/?&page=2#findComment-461876 Share on other sites More sharing options...
