That's a good find. Remember that Monza no longer makes a 240Z muffler, only 280Z, which have horizontal tips similar to your 510 muffler.
The story behind it (being an "orphan") is about the same as how I snagged my early Monza, from before the full muffler that they used for 240Zs at the end.
Edited by Arne
typo
Arne, your Monza muffler looks like dual glass packs. How loud are these mufflers (one post said they sound like angry bees). The input to my muffler is slightly less that 1.75"...how big is the MSA pipe going into their muffler? Thanks for a great post.
What about just cutting off the tips, rotating them 90 deg, and welding them back on? I haven't looked at these so I don't know if it feasible. Just a thought. You wouldn't get that slashed look but it's better than horizontal tips on a Z.
Like this?
I have a 73 240. When I bouight the car it had a stainless steel 2 into 1 system on it. The first 5 feet or so were seperate pipes merging into a 2 1/2' pipe behind the tranny. When I put the round tops on I removed the cast iron manifolds in favor of a header and cut out the dual pipes and went stainless 2 1/2' all the way to the header collector flange. Can't say what if any power gains I got from the header addition, but I know the intake/ exhaust changes gave me a butt load of performance VS. the stock crap I pulled off. BTW I still have the dual stainless pipe and am planning on selling it, since I haven't seen one anywhere else, and from what I can tell the part is mfg. discontinued. Would anybody here have any idea of what it's worth (performance or money wise)?
Edited by 5thhorsemann
The hot setup in the 70's was the Whisper Power exhaust system by Interpart. It used a 6 to 1 header with a 2 1/2 inch pipe and used the standard "turbo" muffler (as in Corvair turbo) that everyone used back then for high performance applications. It finished with a flared chrome exhaust tip. Anyone that was serious about Z performance in those days used this setup or built something similar. The exhaust systems shown above were more for looks and didn't do much for power. If you look through period car magazines like R&T or Car and Driver you will find their ads. How do I know all this? I was there, dude.
Off topic but relevant to the MSA exhaust discussion. IMHO, the MSA Dynomax muffler fits and looks fine. This is the aluminized 2.5" exhaust system, made for the 6 into 1 header. It is pretty darned loud, Ferrari like, for such a small looking tailpipe. I think the Dynomax muffler looks quite tidy under the 240Z. I am considering a resonator right after the header to separate myself from the "tuner crowd".
Edited by cygnusx1
If you go with resonator, make sure it doesn't stop-down the flow. I would recommend a glass-pack to tame the drone while cruising. It is sad that MSA has not addressed this by now. Check this out: http://atlanticz.ca/zclub/techtips/exhaust/index.html
Edited by Blue
cygnusx1 You could replicate with larger pipe one of the old setups, Jones exhaust makes a resonator that matches the size of the SuperSprint resonators, except they don't make one with the inlet and outlet at 1.25", the smallest was 1.5". They have the same body size up-to 2".
A friend of mine got the Z bug and is looking for one well I found this car with a SuperSprint exhaust. It's a 72 and he bought the exhaust in 73, all the resonators are round shape and the tips are rounded in instead of cut flat like mine.
