Posted June 20, 200915 yr comment_287372 I just aquired an intake manifold with the AB valve still intact, My question is, does it operate without the smog pump? It has no large air connections just the small 1/8 inch tubing.Best,H Houghton Link to comment https://www.classiczcars.com/forums/topic/32283-anti-backfire-valve-question/ Share on other sites More sharing options...
June 20, 200915 yr Author comment_287381 searching the site found schematic, apparently this is not the ab valve.:stupid:But what the heck is it for? I am at my office and cant check my parts CD Link to comment https://www.classiczcars.com/forums/topic/32283-anti-backfire-valve-question/#findComment-287381 Share on other sites More sharing options...
June 20, 200915 yr comment_287385 Without pictures, can't say for certain. But I think you are talking about the throttle-close-delay mechanism. If so, it could work without the air pump, but I find its operation annoying. Link to comment https://www.classiczcars.com/forums/topic/32283-anti-backfire-valve-question/#findComment-287385 Share on other sites More sharing options...
