Posted June 25, 200915 yr comment_287866 Hello all, the problem i'm having is that when i put the shifter into 1st gear and if i'm not holding it in place, the shifter slams out of gear. this does not happen in any other gear. it has the t5 borg warner tranny . what could be the cause and how hard would it be to repair ? thank in advance for any help. Link to comment https://www.classiczcars.com/forums/topic/32341-83-280zxt-shifter-jumps-out-o-f-1st-gear/ Share on other sites More sharing options...
June 25, 200915 yr comment_287889 I know when this happened with my 240-Z, I needed a new bearings in the tranny. It started with one gear but very quickly happened in all the other gears. Link to comment https://www.classiczcars.com/forums/topic/32341-83-280zxt-shifter-jumps-out-o-f-1st-gear/#findComment-287889 Share on other sites More sharing options...
June 25, 200915 yr comment_287892 Hello all, the problem i'm having is that when i put the shifter into 1st gear and if i'm not holding it in place, the shifter slams out of gear. this does not happen in any other gear. it has the t5 borg warner tranny . what could be the cause and how hard would it be to repair ? thank in advance for any help.Bearings do not cause tranny to pop out of the gears. They make noise and then collapse. What you have is a bad syncro.Esprist Link to comment https://www.classiczcars.com/forums/topic/32341-83-280zxt-shifter-jumps-out-o-f-1st-gear/#findComment-287892 Share on other sites More sharing options...
June 29, 200915 yr Author comment_288258 how hard is this to repair? or is this something for a trans. shop to do. thanks for your help. Link to comment https://www.classiczcars.com/forums/topic/32341-83-280zxt-shifter-jumps-out-o-f-1st-gear/#findComment-288258 Share on other sites More sharing options...
June 29, 200915 yr comment_288265 Time for a rebuild by a qualified shop unless you are schooled on tranny repair. Pay them to go through it entirely replacing all synchros and bearings. Pay the money and do it once correctly..... Link to comment https://www.classiczcars.com/forums/topic/32341-83-280zxt-shifter-jumps-out-o-f-1st-gear/#findComment-288265 Share on other sites More sharing options...
June 29, 200915 yr comment_288277 how hard is this to repair? or is this something for a trans. shop to do. thanks for your help.I've done a few of them over the years. The first one I did with absolutely no experience. I just followed the manual. The others became successively easier for the experience. But then, I've always been kind of fearless when it comes to things like that. For the most part I've been lucky. Transmissions weren't one of the things I ended up ruining before I learned how to deal with them. (I still won't touch an automatic, however). If you're fairly confident in your mechanical aptitude type skills, I'd say try it. If not, a trans shop would likely be your best bet. Link to comment https://www.classiczcars.com/forums/topic/32341-83-280zxt-shifter-jumps-out-o-f-1st-gear/#findComment-288277 Share on other sites More sharing options...
July 1, 200915 yr Author comment_288520 thanks for the info. Link to comment https://www.classiczcars.com/forums/topic/32341-83-280zxt-shifter-jumps-out-o-f-1st-gear/#findComment-288520 Share on other sites More sharing options...
