Posted June 25, 200915 yr comment_287940 Hey does anyone know of a cam grinding shop in the midwest who does good work?thanks frankie Link to comment https://www.classiczcars.com/forums/topic/32351-cam-grinding-shop-in-midwest/ Share on other sites More sharing options...
June 25, 200915 yr Author comment_287941 check that i don't want to limit myself to the midwest, nation wide does anyone know a good shop to send my cam to be grinded and repaired i have a worn lobe? Link to comment https://www.classiczcars.com/forums/topic/32351-cam-grinding-shop-in-midwest/#findComment-287941 Share on other sites More sharing options...
June 26, 200915 yr comment_287949 Why not buy another cam shaft. Whole lot easier than trying to bring one back from the dead....... Link to comment https://www.classiczcars.com/forums/topic/32351-cam-grinding-shop-in-midwest/#findComment-287949 Share on other sites More sharing options...
June 26, 200915 yr comment_287952 Try Isky Cams. They do excellent work with fast turnaround. www.iskycams.com Link to comment https://www.classiczcars.com/forums/topic/32351-cam-grinding-shop-in-midwest/#findComment-287952 Share on other sites More sharing options...
June 26, 200915 yr Author comment_287955 It would be much cheaper to grind the old cam as the cam kits cost around 800. I would also like to keep my engine stock and its been difficult to find a stock cam. MSA is telling me they are out of stock cams and they said they will continue to look for a distributor as well. These engines are tanks just as is, whats the saying, "don't mess with perfection." Link to comment https://www.classiczcars.com/forums/topic/32351-cam-grinding-shop-in-midwest/#findComment-287955 Share on other sites More sharing options...
June 26, 200915 yr comment_287958 How many stock cam shafts would you like? The owner of ZTherapy said he'd give you one as he does nothing with them so they have assumed surplus laying around growing old gracefully status. Call me for details..... Link to comment https://www.classiczcars.com/forums/topic/32351-cam-grinding-shop-in-midwest/#findComment-287958 Share on other sites More sharing options...
June 26, 200915 yr Author comment_287959 that will make twice i have talked too you this week bruce, im in fort wayne and i just ordered a carb kit from you the other day, ill give you a call tomorrow thanks for the infofrankie Link to comment https://www.classiczcars.com/forums/topic/32351-cam-grinding-shop-in-midwest/#findComment-287959 Share on other sites More sharing options...
