Someone help!
I'm trying to remove the camshaft sprocket nut but when I turn it, the motor turs over. I tried putting a wrench on the crank sprocket, but the engine still turns. How do I keep this from happeining?
Thanks.
https://www.classiczcars.com/forums/topic/32360-l24-cam-sprocket-nut-removal/
i would use an impact
Agreed! I used the screwdriver/wrench trick on the first Z motor I tore down which didn't work so I end up having to buy an impact wrench. I would look back either! Way easier and faster to do many things now including swapping wheels. :)
