Ground Control Coilovers
Diseazd
Sounds like that must have been fun to figure out. If anyone else has Bilsteins, just tell GC and they machine out the inside of the spring hat to allow room for the larger Bilstein strut for you and provide you with spacers to fit the strut shaft and the 5/8" monoball.
FWIW, you will need to still grind the lower "corners" off of the strut nut so that it will seat properly on the monoball with the GC set up. They will send you an instruction sheet for a BMW that details the same thing.
Preith, I am running the exact same set up as you but w/o a rear bar on newly built struts. No spacer needed in front and a 1 1/4" spacer in the rear to get the insert up high enough for the gland nut to lock down. I dropped almost 2 seconds at Nashville last month on 3 year old, rock hard hoosiers. Corner weights were great and with my fat A^% in the car got cross weights to 50/50. I am going to add a little more toe out to the front of the caras 1/16" wasn't enought for the slower sections. Otherwise the car felt great without the rear bar.
Coop, neat way to get your travel back.
2 seconds, great to hear! The real test for myself will be next weekend @ Blackhawk, can't wait! The first event on the Bilsteins was at a new track (for me), but I appeared to be running faster than my nemesis - a wild Ford of England '72 Escort with a twin cam Lotus F2 motor. I'll also be on old rock hard tires deliberately (victoracers at that).
In my case, the car is not loose with the rear bar either.
For anyone interested, here's a vid from the aforementioned race - from Bill's perspective in the ex-Mountain Motorsports ITS 240. Unfortunately he was just a bit too far back to catch my duel with the Escort, just a dot in the distance. I missed the grid call and started a lap down (don't ask why :mad:) , doh! Ran with the escort for about 5 laps but let up after that, what's the point?
Edited by preith
Here's an update on the camber plate installation......I didn't dare put 'em on top......didn't want to take the verbal abuse from you guys!! Will post the pics of the coilovers and brakes later. Thanks for your advice. Guy
Edited by Diseazd
Here are some more photos of my dad's car.
<a href="http://www.flickr.com/photos/14049800@N00/3736890236/" title="IMG_3562 by RVAE34, on Flickr"><img src="http://farm3.static.flickr.com/2423/3736890236_5ddb9bd0be_b.jpg" width="1024" height="684" alt="IMG_3562" /></a>
<a href="http://www.flickr.com/photos/14049800@N00/3736096477/" title="IMG_3573 by RVAE34, on Flickr"><img src="http://farm3.static.flickr.com/2427/3736096477_2d28d4697a_b.jpg" width="1024" height="684" alt="IMG_3573" /></a>
<a href="http://www.flickr.com/photos/14049800@N00/3736097643/" title="IMG_3565 by RVAE34, on Flickr"><img src="http://farm4.static.flickr.com/3502/3736097643_175071d2c7_b.jpg" width="1024" height="684" alt="IMG_3565" /></a>
<a href="http://www.flickr.com/photos/14049800@N00/3736891598/" title="IMG_3566 by RVAE34, on Flickr"><img src="http://farm4.static.flickr.com/3440/3736891598_8a4b9ba637_b.jpg" width="1024" height="684" alt="IMG_3566" /></a>
<a href="http://www.flickr.com/photos/14049800@N00/3736099151/" title="IMG_3567 by RVAE34, on Flickr"><img src="http://farm4.static.flickr.com/3478/3736099151_2698271e53_b.jpg" width="1024" height="684" alt="IMG_3567" /></a>
<a href="http://www.flickr.com/photos/14049800@N00/3736099943/" title="IMG_3568 by RVAE34, on Flickr"><img src="http://farm3.static.flickr.com/2439/3736099943_27d904df78_b.jpg" width="1024" height="684" alt="IMG_3568" /></a>
<a href="http://www.flickr.com/photos/14049800@N00/3736100565/" title="IMG_3569 by RVAE34, on Flickr"><img src="http://farm3.static.flickr.com/2619/3736100565_ddcec11a06_b.jpg" width="1024" height="684" alt="IMG_3569" /></a>
WOW!!! What a difference the new Willwood's and coilovers make.....you can get the car right down on the ground and when you stop, your face feels like it keeps on going! Thanks Jamie and Russ!
Edited by Diseazd
Hi guys
i wanted to add something to this discussion...
i am in the process of doing the same mod to my 73 as well.
have the struts sectioned and the new perch welded on.
Need to worry about the top of the strut towers now as well.
it's good to hear you recommend XXX 1/8" plate for the reinforcing plate.
XXX
anyways, my question here is regarding hubs...
can i re-use my 240hubs on the 280 struts or do I need to swap those out to 280 as well?
Thanks guys,
-e
Edited by EricB
I mis-typed
Jon
sorry. I mis-typed. I was referring to the post you have on the previous page about making 4 reinforcing plates from the template and putting them on the underside of the strut tower... my bad.
regarding the hubs though, can I use 240Z hubs on 280z spindle/strut housings?
Or does everything need to be 280z up front for caliper/rotor to line up right?
Thanks,
-e
When I ordered my brakes from Arizona Z Dave sent me hardware that worked with 240z hubs. You need to specify which hubs you've got when you order because of the different offsets. I bought the Willwoods.
Do the 240 hub parts fit a 280 strut though? The caliper mount (integral to the strut housing) has to be inline too, which is why it is easier/safer to stick with 280 parts or 240 parts, and not mix and match.
  • Who's Online   0 Members, 1 Anonymous, 521 Guests (See full list)
