Not sure what it is called but it is the bar that sprays the rocker arms with oil.
I need one as I noticed when adjusting my valves that one end was very loose and the middle bar pretty much spun freely. On a side note how much would this affect my oil pressure.
If anyone has a spare please let me know how much or where I can get one.
Thanks,
Mike
https://www.classiczcars.com/forums/topic/32402-rocker-arm-oil-sprayer/
You can just clean the metal and solder {or braze} the tubes back in place. They weren't welded in there to begin with.
Oil pressure - is really needed to support the main bearing/crank interface. Past that point oil volume is more an issue. The spray bar provides a good volume of oil distributed along the cam/rocker interface, and that oil then drains back to the pan. So the condition of the spray bar has little to no effect on oil pressure.
FWIW,
Carl B.
