fuel lines/ brake lines
Does anybody know the diameter on the brake lines? Can I use stainless steel or do I need a special marterial? I plan to do it in Dec or Jan, but since I live down in Mexico its harder to get all the things. I still have to order the tube cutter, the tube bender and the kit for the double flare
Can you guys help me out in this predicament
Replacement brakelines will be 3/16" with japanese nuts on them.
AGS brand will have a part number that begins with BLJ followed
with the length.
Here is a list with numbers for the correct parts for the Z.
These are all AGS part numbers (American Grease Stick)
BLJ-308 (8")
BLJ-312 (12")
BLJ-320 (20")
BLJ-330 (30")
BLJ-340 (40")
BLJ-351 (51")
BLJ-360 (60")
10 X 1.0mm AGS Union BLC-9U, Edelmann 27400, Weatherhead 7934A,
Continental WUB596
10 X 1.0mm Japanese tube nut for 3/16" tube
BLF-40C-5 - Carded (5 fittings per card/10 cards per case)
BLF-40B - Individually Bagged (1 fitting per bag/10 bags per case)
BLFX-40 - Bulk/Boxed (100 fittings per case/box)
BLF-40 - Bulk/Bagged (10 fittings per case/bag)
Another nice product that works well on the Z's is
AGS PolyArmour PAC-325 BRAKE LINE (its 3/16")
This brake bending pliers is the best I have found for our Z's.
http://cgi.ebay.com/ebaymotors/New-Datsun-240Z-280Z-Brake-line-Pliers_W0QQcmdZViewItemQQ_trkparmsZ65Q3a12Q7c66Q3a2Q7c39Q3a1Q7c72Q3a1205Q7c293Q3a1Q7c294Q3a50QQ_trksidZp3911Q2ec0Q2em14QQhashZitem1c0b1def9cQQitemZ120445595548QQptZMotorsQ5fAutomotiveQ5fToolsQQsalenotsupported
This seller ships world wide and can get the lines also, but you
will need to bend them.
Edited by Maples71240Z
