Posted July 5, 200915 yr comment_288775 I was just wondering what the similarities were with the 240Z/260Z/280Z and the 510 suspension. Will the 280Z lower control arms, tension rods etc. fit the 240k? Would the rear brake conversion for a Datsun 510 work for a 240K? What suspension parts off of these cars would fit? does anyone know? Link to comment https://www.classiczcars.com/forums/topic/32434-suspesion-similarities/ Share on other sites More sharing options...
July 7, 200915 yr Author comment_288931 you got to be jokeing. no one knows anything?well, so far I found out that the rear lower control arms from a 510 will fit a GC111/240K. Also, if the front 280Z and DR30 struts will fit the 240k/GC111 then the lower control arms have to be the same. I guess I just answered my own question. BUt I am still not sure about the tension rods. CAN ANYONE HELP!? Link to comment https://www.classiczcars.com/forums/topic/32434-suspesion-similarities/#findComment-288931 Share on other sites More sharing options...
July 7, 200915 yr comment_288943 If the 510 rear arms fit, do the springs, shocks and other parts interchange? Since I'm in the states, if the 510 suspensions are the same, it will make getting parts much easier. I don't know about the struts or tension rods. The previous owner of my car convered to 280z struts with coil overs, but there is not much adjustment on this system and I only have about an inch availble for suspension travel. I think the 280z struts might be longer. All the front end suspension parts are stock Nissan/Datsun on my car. I know some people on here have gone completely custom.My car is a '77 GC111, but I have found that all GC111, GC110 and 240K have the same suspensions. I think GC10 stuff might interchange as well from looking around the internet.Chris Link to comment https://www.classiczcars.com/forums/topic/32434-suspesion-similarities/#findComment-288943 Share on other sites More sharing options...
July 8, 200915 yr Author comment_289015 Wow, good to see that car in Cali. I'm from Pasadena, but I'm stationed over here in Tokyo. I found this website:http://sp-tec.com/looks like the rear 510 lower control arms will fit. What have you done to your ride? R200,R32 brakes, master vac, etc.I've got another 8 months before I head back to the states. GC10 struts will fit too. Link to comment https://www.classiczcars.com/forums/topic/32434-suspesion-similarities/#findComment-289015 Share on other sites More sharing options...
October 17, 200915 yr comment_297707 Nice Link Tyrone, Certainly an interesting way to setup an adjustable height spring in the rear A Lot of the Datsun 1600/510 guys use the C110 rear arms as they are supposedly stronger. The rear brake upgrades that the 510 guys do, in theory should work on the C110 too (ie. the DR30/maxima caliper plate).. i say in theory as i never actually completed it.. but i am 90% sure it would have Would love to know the answer on the TC rods too.. atleast C110 specific TC rods can be found in japan (unlike anywhere else!) Link to comment https://www.classiczcars.com/forums/topic/32434-suspesion-similarities/#findComment-297707 Share on other sites More sharing options...
October 19, 200915 yr comment_297867 i have heard of people using 240k rear arms in 1600 rally cars. they have bigger bearing housings and a reinforcing plate over the axle. i have just completed an R31 rear disc conversion in my 240k using hardware from a datsport 1600/P510 kit. it works but the hole in the caliper mounting plate must be heaps bigger. Handbrake cables had to have the cable shortened and the sheath lengthened. the 7/8 master struggled a bit with hilux 4 pots as well as R31 rears and was replaced with 15/16 ZX job. oh and P510 tension rods wont fit, wrong shape i have used 200B tension rods which are a bit shorter. Link to comment https://www.classiczcars.com/forums/topic/32434-suspesion-similarities/#findComment-297867 Share on other sites More sharing options...
October 23, 200915 yr comment_298278 Hey guys, nice to see some other C110 owners in the states! I have a similar question, the idler arm bushing in my 73 240k is done. It looks like the 510 and 240z have different idler arms. Do you guys know of any other Datsun model in the states that may have the same one? Edited October 23, 200915 yr by circuitlife86 spelling Link to comment https://www.classiczcars.com/forums/topic/32434-suspesion-similarities/#findComment-298278 Share on other sites More sharing options...
October 23, 200915 yr comment_298302 Circuitlife, i can give a parts place a ring on monday and see if they are available if you need a set.do you need just the bushing, or the whole arm? Link to comment https://www.classiczcars.com/forums/topic/32434-suspesion-similarities/#findComment-298302 Share on other sites More sharing options...
October 26, 200915 yr comment_298610 Kent,If you give do call, can you post the results here. I have been looking all over the globe for either bushings or a complete arm. I even called up a distributer in Australia myself. No luck, they said the arm was no longer manufactured. The one they did list was incorrectly marked for the 240K.See this thread for the saga I went through;http://www.classiczcars.com/forums/showthread.php?t=31008Right now planning to go the bearing/bushing/sleeve route. Or a completly custom arm, but that's big $$$$.Circuitlife, good luck in the search. I was thinking about calling these guys, as they might have a parts source directly from Japan. www.righthanddrivejapan.comI think you'er in the same business (if you'er the guy with the classic skyline shop in Salt Lake), so if you can't get parts, I don't know who can.Chris Edited October 26, 200915 yr by ctcurnes Link to comment https://www.classiczcars.com/forums/topic/32434-suspesion-similarities/#findComment-298610 Share on other sites More sharing options...
June 29, 201113 yr comment_360153 I know this is an old post but since it was already there & does cover part of my quesiton I'll just add to it. Im thinking about running 280z front struts on my c110. However I wanted to confirm since the original post was in 2009 has anyone been able to confirm if any of the z struts work with the c110? or are they too long as stated above?Next has anyone attempted to use S13 coilovers on a c110? Its my understanding they work on c10 but not certain about a c110.Any and all feedback is greatly appriciated. Link to comment https://www.classiczcars.com/forums/topic/32434-suspesion-similarities/#findComment-360153 Share on other sites More sharing options...
June 30, 201113 yr comment_360215 http://forums.hybridz.org/index.php/topic/95443-j-rex-from-team-shogun-s130-with-s13-coil-oversuse that as a guide :> Link to comment https://www.classiczcars.com/forums/topic/32434-suspesion-similarities/#findComment-360215 Share on other sites More sharing options...
